Drives: 14 BRZ, Genesis coupe track, 05 sti
Transmisión leaking and 4th gear not doing well
Hello fellow members,
What would I need to swap a cd009 to our platform? Sent from my Pixel 3 using Tapatalk |
Drives: Q5 + BRZ + M796
I'm not really sure. These are the things that need to at least be sorted out:
CD009 Custom Transmission Mounts Custom Adapter Custom Driveshaft Hammering Shifter Position TOB Shift Fork Position I don't know about the input shaft. Would it need to be machined? What type of clutch would work? Would a 370z pressure plate be needed to work with the input shaft, but a regular flywheel be needed for the 86's engine? Will the pilot bearing work or a new one found with a different inner diameter but the same outer diameter? Would a shift fork from the CD009 line up with the stock position for the clutch cylinder? Will the shifter line up with the stock location? I haven't seen too many transmission swap threads, but if someone could sort out these issues then I'm sure there would be interest. I will be either rebuilding my transmission or rebuilding a donor, lightly-used transmission or considering a swap. I want a 6 speed and something that can reliably handle power upgrades up to around 500whp. I was thinking the CD009 or the S2000 transmission, but the CD009 would be the stronger choice, as I understand it.
#3 | |
Project Shadow
Drives: 2015 BRZ Limited 6MT
I just saw a post on instagram that FBM released a kit for the BRZ/FRS. This link isn't it but it's something to look at and an idea on price. They didn't say how much yet that I know of, but I bet if you give em a call and ask they will give you some info.
http://fullblownmotorsports.com/full...ion-conversion
#5 | |
#6 | |
I Love custom Turbo kits
Drives: Limited BRZ
https://www.mazworx.com/mazworx-favq...t-frs/brz.aspx
Drives: Limited BRZ
Unfortunately, no magic will help on that
| Partial Part Out, Engine, Turbo Kit with 3" exhaust, Driveshaft, Transmision | Sportsguy83 | Engine, Exhaust, Bolt-Ons | 8 | 02-16-2017 05:25 PM |
| Loud Hum/Grinding Noise + Vibration in 5-15mph gear range, in gear and rolling neutrl | jakebrz | Issues | Warranty | Recalls / TSB | 14 | 06-06-2016 06:28 PM |
| Transmision Problems Question | kombatlion | Engine, Exhaust, Transmission | 4 | 05-14-2014 11:59 AM |
| Oil leaking.. | Senzai | Issues | Warranty | Recalls / TSB | 3 | 10-02-2013 12:02 AM |
| Leaking Oil? | 636 | Issues | Warranty | Recalls / TSB | 11 | 01-05-2013 04:43 PM |
