Drives: 2013 Scion FRS
Car won't turn over
Anybody know what this issue could be? All the lights work, but it's like it's stuck in accessory and won't turn over. The only noises coming from under the hood is a buzzing.
Sent from my SM-G955U using Tapatalk |
#2 |
The Gunshine State
Drives: '14 BRZ Limited
Battery may not have enough juice to crank or bad starter.
![]() Current DD: M235i |
#3 |
I'll check that. I have a video of what's going on, but it's too big to upload it here, unfortunately
#4 |
Battery is low. The buzzing is the starter solenoid trying to engage. The lights work because they don't need near the amperage the starter does.
#5 |
Rust bucket enthusiast
Just had someone who this happened to after they tried to flash a tune to their car that was for the incorrect ECU version. They had to buy a new ECU. Had you just done a reflash? This is PROBABLY just the starter, as everyone else has said.
#6 |
Drives: Subaru BRZ
Check your alternator, if the battery is dead the alternator could be the cause
#7 |
Famous Potatoes
Drives: '15 ultramarine
Original battery? If so, maybe your 6 year old battery is on it's way out.
#8 | |
#9 |
#10 | |
Undisputed El Presidente
Drives: Zenki 37J ZN6
Check what it drops to when starting the car? Under 9 and it's probably toast |
#12 |
#13 | |
A normal battery should be around 12.5v iirc when off. And stay above 9 when trying to start. |
#14 | |
| Turn as tail timing not matching with the front turn signals | NahumCC | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 01-03-2016 10:40 PM |
| Steering wheel issue---left turn lighter than right turn!!! | xingxingtjf | Issues | Warranty | Recalls / TSB | 12 | 10-14-2015 06:47 PM |
| Voice Commands with new turn by turn in IOS6? | jadewbj | Electronics | Audio | NAV | Infotainment | 0 | 09-21-2012 10:11 AM |
