Old 02-04-2019, 08:24 AM   #1
kev0
Drives: '14
Morimoto HID in OEM Housing?
Anyone running Morimoto HID's or any other HID kits out there on their OEM Housing? Is it as bad as people say? I'm not trying to be the asshole that's blinding everyone else on the road so I'll be aiming it a bit lower.
For those who are running HID's in stock housing: how do you like it? I'm currently using LED's and they're better than the halogens, but I still cannot really illuminate more than 40 feet in front of me on a completely dark road. I hit a dead raccoon on the street earlier because I couldn't see it with my LED's poor illumination.
kev0 is offline   Reply With Quote
Old 02-04-2019, 12:46 PM   #2
YamahaR86
JDM Vaping Stance Nation
YamahaR86's Avatar
Drives: 2013 White
I've use it in OEM housing before and it's not that bad. What IS bad is running it in reflector housings like most cars do. The light is scattered in those.
In OEM at least you have projectors to control it somewhat.
Clueless
YamahaR86 is offline   Reply With Quote
The Following User Says Thank You to YamahaR86 For This Useful Post:
wparsons (02-07-2019)
Old 02-04-2019, 12:49 PM   #3
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I run Acura HID's (from an old project) that are retrofitted into my OEM 2013 FR-S Highbeams. I think they look great. When Shining on the side of my shop, the beams look even. My low beams are stock.
The acura HIDs are 35 watt. Same as the OEM highs. The ballast plugs were even the same! I could not believe it. I had to modify the lights though.
I LIKE TIRES!
Old 02-07-2019, 12:35 PM   #4
1quickchic
Drives: 2013 Panda ft86/FRS
I have a kit on mine as well, and think its fantastic, there is a very visible cut-off line, and I can see better. I am using some old 35w ballasts and xenatech bulbs. lol cheap ftw!
1quickchic is offline   Reply With Quote
Old 02-07-2019, 07:20 PM   #5
HeresMyMind
HeresMyMind's Avatar
Drives: 2013 WRB BRZ Limited
Putting HID's in Halogen projectors is only going to improve the lighting. It wont be as good as projectors specifically designed for HIDs.
You still still have a usable cut off that won't cause glare to oncoming though.
I've been retrofitting headlights since 2004 and can help if you have any questions. I have a thread specific for that in this category!
-B
HeresMyMind is offline   Reply With Quote
Old 02-15-2019, 10:58 PM   #6
HaXx
Drives: jrsc_brz
just bought fog lights from this guy ^^^^ and hes the real deal, super nice to work with, and affordable. take his word when it comes to lighting.
HaXx is offline   Reply With Quote
Old 02-16-2019, 01:22 AM   #7
soundman98
ProCrastinationConsultant
soundman98's Avatar
-B
i knew the name looked familiar from somewhere
Old 02-16-2019, 08:22 AM   #8
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Even the best LEDs aren't even close to HIDs.
Most halogens max out at ~1700 lumens
Morimoto's best LEDs output 2400 lumens
Even cheap xenon bulbs typically do 3400 lumens.
Old 02-16-2019, 08:23 AM   #9
Yoshoobaroo
TRACKBREAD
Try the xenons in the OEM housings, my bet is you'll be pleased.
Morimoto Headlights Alltezza Cosmetic Modification (Interior/Exterior/Lighting) 203 02-06-2021 08:30 AM
MORIMOTO LED Foglights Dan37BRZ Exterior Parts (Aero, Lighting, Etc.) 4 03-10-2018 01:57 AM
PTE 6466, 1.0 divided A/R, polished comp housing, black ceramic turbine housing slicktop Engine, Exhaust, Bolt-Ons 6 10-17-2015 10:53 PM
6K H11 Morimoto HID Kit Zero90 Exterior Parts (Aero, Lighting, Etc.) 2 05-20-2014 12:49 PM
Help Morimoto HID kit Jacob G. Cosmetic Modification (Interior/Exterior/Lighting) 4 02-18-2013 02:03 AM
