Old 02-02-2019, 07:04 PM   #1
Katsutoshi
Katsutoshi's Avatar
Drives: 2016 Scion FR-S
Extra intake filter
Hello! I was researching the cabin sound tube delete this morning, and had a crazy idea which I am wondering if anyone else has tried. Has anyone tried putting an extra K&N filter on the port into the intake when they delete the cabin sound tube? I doubt it would add much power but I thought it might allow *some* extra airflow.
Katsutoshi is offline   Reply With Quote
Old 02-02-2019, 07:55 PM   #2
86MLR
86MLR's Avatar
Hot air = bad
http://www.ft86club.com/forums/showthread.php?t=133311
I'm only here for the biscuits
The Following User Says Thank You to 86MLR For This Useful Post:
Katsutoshi (02-02-2019)
Old 02-02-2019, 09:18 PM   #3
Cal3000
Drives: Panda FR-S
That would be kind of useless. Your engine is designed to vacuum a certain amount of airflow. The stand alone stock intake tube has enough diameter to fulfill the engine air intake needs.
The only reason after market intakes may be somewhat useful is that most are straight pipe tubing with no acoustic deadening ribs, which helps with more laminar air flow.
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
242whp/197ft-lb on Mustang Dyno (91 octane water)
284whp/223ft-lb on Mustang Dyno (E85)
Cal3000 is offline   Reply With Quote
The Following User Says Thank You to Cal3000 For This Useful Post:
Old 02-02-2019, 10:18 PM   #4
Katsutoshi
Katsutoshi's Avatar
I figured there was a good reason. Just couldn't find the subject approached anywhere, thank you both for your input!
Old 02-02-2019, 10:40 PM   #5
humfrz
That's been tried -
humfrz
Old 02-02-2019, 10:48 PM   #6
Kaotic Lazagna
Drives: GR Corolla
That's been tried -
humfrz
That reminded me of this:
[ame]https://www.youtube.com/watch?v=IHTS5kiBsJw[/ame]
The Following User Says Thank You to Kaotic Lazagna For This Useful Post:
humfrz (02-02-2019)
Old 02-02-2019, 10:53 PM   #7
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
This is a pretty popular mod on the turbo 6 BMWs. Not sure if it would help us that much though.
Keep in mind that if you plan on experimenting with it, you have to add the extra intake BEFORE the MAF sensor, the sound tube plugs in AFTER.
Old 02-03-2019, 03:27 PM   #8
Katsutoshi
Katsutoshi's Avatar
that was hilarious
The Following User Says Thank You to Katsutoshi For This Useful Post:
Kaotic Lazagna (02-03-2019)
Old 02-03-2019, 03:28 PM   #9
Katsutoshi
Katsutoshi's Avatar
Very good point! I hadn't looked that closely!
intake, sound pipe delete
TRD Intake Filter Air Filter Cleaner Element FRS BRZ 86 Toyota Racing Development hirollaz Engine, Exhaust, Bolt-Ons 0 03-15-2017 02:46 AM
.: GReddy Air Intake System · Increases intake airflow · 4 Layer filter :. Speed Element Engine, Exhaust, Bolt-Ons 14 05-20-2013 06:06 PM
