Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AUSTRALIA
AUSTRALIA Australia and New Zealand
Old 02-01-2019, 12:41 AM   #1
Bodalenko
Steve Bodalenko
Drives: Toyota 86 GTS
Who’s running either Cusco or OS Giken 1.5 LSD’s?
Trying to decide between the Cusco or Giken 1.5way diff.
Would be interested in opinions of those that have either fitted re chatter when turning, noise, and daily drivability.
Cusco gets a thumbs up but is $400 dearer than Giken, which has a similar
if not better name and is drop in and play v backlash checking with Cusco. Also need specific Diff oil with Giken though apparently that can be gotten around..
Opinions?
Bodalenko is offline   Reply With Quote
Old 02-13-2019, 05:59 PM   #2
fuddbutter
Potato Farmer
fuddbutter's Avatar
Drives: #SLOBRZ
Might be a bit late, but I believe the Cusco is just the TRD diff, they just sell it with their own name on the box
http://trdparts.jp/english/86_perfor...owertrain.html
Something something butter..
www.vic86brzclub.com
fuddbutter is offline   Reply With Quote
Old 02-19-2019, 10:11 PM   #3
Bodalenko
Steve Bodalenko
Thanks for that.. would not be surprised. Thinking of going the OS GIken 1.5 way at this stage. Gets good reps, is said to be DIY and works out a couple of hundred cheaper than the CUSCO for whatever reason. I guess the TRD loading. I’ll pick up a good second hand diff I can fit it to so I can just swap OEM diff for the other, or should I say get Chasers to do it..
Old 02-27-2019, 07:00 PM   #4
fuddbutter
Potato Farmer
fuddbutter's Avatar
Drives: #SLOBRZ
Mine was at Chasers last week getting some work done, new rotors/pads and diff/GB oil change.
Giken clutches Jmonty Engine, Exhaust, Transmission 13 10-09-2017 01:15 AM
OS Giken LSD + 4.8 FD. Do they fit together? Rookie84 Engine, Exhaust, Transmission 3 05-21-2015 05:34 AM
Which LSD to take: Cusco or OS Giken mrbbs Engine, Exhaust, Transmission 19 12-05-2014 11:17 AM
Installed Cusco Catch can wrong? Running lean goshem Engine, Exhaust, Transmission 17 08-19-2014 03:06 PM
A really good comparison between OS Giken and Cusco Erik @ GBox Engine, Exhaust, Transmission 1 10-19-2012 10:50 PM
