Old 01-28-2019, 07:06 PM   #1
Puttputt7
Drives: 2016 Scion fr-s
CLANK noise when going from reverse to 1st - random squeals when turning
Info:
- FRS 2016
- 25k mi
- Factory
Whenever I go from reverse to 1st and i have to crank my wheel all the way, (say backing out to a 90 degree angle) when I go into first and start driving i get a clank noise.
Recently i've noticed when driving in 1st or 2nd and driving around a parking garage I can hear squeeling/creeking coming from the steering wheel (or maybe wheel area), but it only happens about 40% of the time.
Do you think
- CV joint?
- Strut?
- Brace?
Puttputt7 is offline   Reply With Quote
Old 01-28-2019, 07:27 PM   #2
humfrz
Originally Posted by Puttputt7 View Post
Info:
- FRS 2016
- 25k mi
- Factory
Do you think
- CV joint?
- Strut?
- Brace?
Hello Puttputt7 and welcome to our forum -
I reckon that clank noise could be caused by any number of things in the drivetrain (clutch, TOB, transmission, driveline universals, differential, rear axles, axle nut) or something binding or unbinding in the braking system of a wheel.
Boy, now don't THAT narrow it down -
I suggest you round up a buddy, one drive, the other listen, to see if you can tell where the sound is coming from.
Your second observed sound could be a lot of things also. Starting with "in a parking garage" - one could hear all kinds of sounds. It could be a tire on the concrete, could be a brake pad dragging, could be a slightly sticking caliper. It could simply be the electric power steering system doing its thing.
Again, can you isolate where the sound is coming from?
The third possibility that it's all in your head - (this car makes a lot of strange sounds).
humfrz
Old 01-29-2019, 12:11 AM   #3
Brz_racer
Drives: Subaru BRZ
If the car drives fine I wouldn't be too concerned about it, every now and then someone (myself included) posts that they have heard an odd sound from their BRZ or FR-S. This is normal, as all cars make noise its just more noticeable in this car as there is almost no sound deadening. If the car drives like it should I wouldn't be too worried about it. Another thing is this transmission particularly the manuals make a lot of noise when cold. The other thing is at 25k you are still under warranty, you could take it to the dealer and let them have a listen
Brz_racer is offline   Reply With Quote
Old 01-29-2019, 12:23 AM   #4
Decep
Drives: 2013 FR-S Series 10
Easiest thing to check would be your strut mounts under the hood. Make sure they're torqued down. Barring that i would probably take it into a good shop where they can inspect your suspension. They'll generally charge you an hour's labor to double check your bushings/fasteners/balljoints etc. These are noisy cars but i dont think clanking sounds are normal when turning the steering wheel.
Old 01-29-2019, 12:33 AM   #5
Brz_racer
Drives: Subaru BRZ
They are in the BRZ lol I get it all the time
Old 01-29-2019, 12:45 AM   #6
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
The random squeals i get come from the brunette sitting next to me.
Sorry, I'm bored.
Old 01-29-2019, 12:55 AM   #7
Brink
Drives: 2017 BRZ
Sorry, I'm bored.
Next to you? Why so far away?
Brink is offline   Reply With Quote
Old 01-29-2019, 02:05 AM   #8
humfrz
Sorry, I'm bored.
QUIT PINCHING HER!
Grinding Noise When Turning Left ThatAsianBradah Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 7 03-20-2023 11:55 AM
Noise when turning Autoenthusiastasm BRZ First-Gen (2012+) — General Topics 7 01-21-2019 10:14 PM
Hissing noise after turning off car Coop Issues | Warranty | Recalls / TSB 7 09-14-2018 01:28 PM
AP Sprint clicking noise when turning 1Cor10:23 Tracking / Autocross / HPDE / Drifting 14 02-14-2017 11:41 AM
Weird hmmming noise when turning?? congee Issues | Warranty | Recalls / TSB 8 09-08-2015 12:29 AM
