Old 01-18-2019, 09:44 PM   #1
Autoenthusiastasm
Drives: 2013 BRZ Limited - stock
Noise when turning
I have read about a whine when turning associated with electric power steering. My car has 41000. I have owned it for 1000 miles and did not have have this problem until now. So when I turn at slow speeds I hear a whining noise from the steering column. I also feel it in my gas pedal. Is this different than the standard problem? Should I be concerned.
Autoenthusiastasm is offline   Reply With Quote
Old 01-20-2019, 11:32 PM   #2
Brz_racer
Drives: Subaru BRZ
The power steering pump is electric and as such makes some noise. I wouldnt be too concerned about this if your steering is working properly. If It takes excessive effort to turn in either direction you might consider changing the pump.
Brz_racer is offline   Reply With Quote
Old 01-20-2019, 11:34 PM   #3
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Consider also that we've been getting serious snow/cold up here in the north east. See if it subsides with warmth
Old 01-21-2019, 12:04 AM   #4
Ultramaroon
not playing cards
Ultramaroon's Avatar
It's not a pump. It's a servo motor right on the column under the speedo. It should only ever make a slight whirring sound while the steering wheel is rapidly being rotated. Otherwise it should be dead silent.
Spuds (01-21-2019)
Old 01-21-2019, 08:32 AM   #5
gravitylover
I had that last winter and they ended up replacing all sorts of parts from the steering wheel to the entire steering column and servo motor. The noise pretty much stopped after the column replacement. It was very disconcerting to hear it and feel it in the gas pedal and through the floor under my left foot.
Old 01-21-2019, 08:40 AM   #6
This ^
And this ^
Mine does it when it is cold out. When really cold all the grease in the fittings through the steering firms up a bit and the motor has to work a little harder to move it all. It should go away when warm out again.
And maybe this ^
If it doesn't go away when warmer again then you may have an issue! Pretty rare problem though.
Old 01-21-2019, 05:13 PM   #7
Autoenthusiastasm
It’s true that I did not notice it until it got cold out. I hope it’s not the same problem that gravitylover had. Gravity. How much did it cost to fix? Thank you everyone for your feedback
Old 01-21-2019, 10:14 PM   #8
gravitylover
Other than some gas in the loaner car nothing because it was under warranty. I could pull the paperwork but I want to say it added up to nearly $2k.
Grinding Noise When Turning Left ThatAsianBradah Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 7 03-20-2023 11:55 AM
Hissing noise after turning off car Coop Issues | Warranty | Recalls / TSB 7 09-14-2018 01:28 PM
AP Sprint clicking noise when turning 1Cor10:23 Tracking / Autocross / HPDE / Drifting 14 02-14-2017 11:41 AM
grumbling noise from front end when turning vramsaran Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 04-26-2016 07:29 PM
Weird hmmming noise when turning?? congee Issues | Warranty | Recalls / TSB 8 09-08-2015 12:29 AM
