JDM Vaping Stance Nation
Drives: 2013 White
Dealership Service Prices, worth it?
I typically avoid doing any service at the dealership unless it's major and follow the DIY threads on here.
I just took my car in MY13 for the valve spring recall. It's at 42k miles. Advisor also mentioned some services he recommended and I'm not sure if I should do it or not if it's an issue. Tune Up $159.95 (Not even sure what this even includes). Water Pump $339.95 (Is this a known issue?) Throw out bearing $99.95 (I know there were a few issues and mine might have it since I took it in once before for a squeaky clutch pedal).
Clueless
#2 | |
Drives: '13 BRZ Limited
The Part is $55 list from Subaru - you can get the Toyota one for like $23 (IIRC) list and about $18 online, but... It's probably 5 minutes of work even if you take your time and clean up the input shaft collar, and the fork and re-grease the contact points... so their labor rates seem high, but it's a LOT less than having to drop the transmission later on. |
| The Following User Says Thank You to 86league For This Useful Post: | YamahaR86 (01-22-2019) |
Panda Trueno
Drives: No twin now.
Find out what is involved in their "tune up" but I would say changing the spark plugs is a great idea while that recall is being done.
The throwout bearing seems like an easy fix while they're in there as well, and it would be nice to have the new part. Cheaper than having it done later and dropping the trans. Water pump..... I would personally skip on that. That hasn't been shown to be a high failure rate item. It IS probably an easy part to replace while they have the motor apart though. At 42K though and no prior issues.... it isn't likely (IMO) to fail any time soon. |
| The Following User Says Thank You to Summerwolf For This Useful Post: | YamahaR86 (01-22-2019) |
#4 | ||
Drives: 2013 White
I just did some forum research and apparently the TOB part that fixed the issue was released in 2017. My main concern as you addressed is trying to do it by myself having to drop the transmission/major engine parts when I don't have the tools to do so (just have basic garage tools) so I am highly considering it. Quote:
I looked at my maintenance sheet and saw my spark plugs are at 60k miles. I haven't looked at doing them yet but are they a pain? With this engine it seems like it would be easy with a lot of things being accessible on top. The water-pump does seem high to me and I did some quick searching and people say it's easy to replace (near the belt I believe) so I think I may be able to do that myself. Thanks!
Clueless
Drives: frs
Check this video:
#6 | |
Panda Trueno
It's a no brainer to do those while the engine is out and apart. |
I would do the things that cost a lot due to manpower.
Spark plugs TOB Clutch Having any of those fail within the nex 20k miles would make it money well spent. |
| The Following User Says Thank You to Grady For This Useful Post: | YamahaR86 (01-22-2019) |
Drives: '14
Adding onto this.. going to a dealership for service will have it noted on a Carfax report. Useful when it comes to selling your car.
[insert cool phrase here]
Drives: BRZ Premium
Any mechanic shop that pays to be in the Carfax system can do it. Hell, even jiffy lubes can do it.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
| Is this detailing service worth it? | Captain.K | Southern California | 12 | 02-21-2015 12:30 PM |
| Which dealership for service? | Drive | Northern California | 23 | 01-25-2015 05:37 PM |
| First service from dealership | JayDee | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 24 | 04-02-2014 02:41 PM |
| Best dealership for service?? | booyaka | Northwest | 6 | 01-17-2014 10:14 AM |
| Which dealership for first service? | randomweather | CANADA | 1 | 12-23-2012 01:57 PM |
