Old 01-22-2019, 12:25 AM   #1
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
How to install Vorshlag rear shock mounts
This video shows how to properly configure MCS, or similar style coilover, suspension when using the Vorshlag rear shock mounts.
Originally I had used the OEM spring hats instead of the MCS supplied spring hats (which worked ok). This process shows how to assemble the rear shock when using all of the correct parts (non-OEM).
[ame]https://www.youtube.com/watch?v=O4vln10znJM[/ame]
justinco is offline   Reply With Quote
Old 01-22-2019, 06:29 PM   #2
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
why did you switch spring order? does it even matter?
Breadman is offline   Reply With Quote
Old 01-22-2019, 06:37 PM   #3
eastendraceshop
eastendraceshop's Avatar
Drives: '13 Scion FR-S & '17 Toyota 86
Thanks for sharing Justin! Very helpful and informative video!
eastendraceshop is offline   Reply With Quote
The Following User Says Thank You to eastendraceshop For This Useful Post:
justinco (01-22-2019)
Old 01-22-2019, 06:45 PM   #4
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
I don't think it really matters. My RCE T2's were shipped with them on top, so that is how I put together the MCS originally. Vorshlag shows the helper spring on the bottom in their updated photos, so I just switched to that.
FS: FRSport DIF MCS Rear Shock Mounts M0nk3y Brakes, Suspension, Chassis 5 05-10-2018 07:36 PM
How Crucial Are Radial Bearings in Rear Shock Mounts? RJasonKlein Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 10-22-2016 01:45 AM
Trying to understand rear shock top mounts... Stang70Fastback Suspension | Chassis | Brakes -- Sponsored by 949 Racing 32 10-10-2016 12:43 PM
Raceseng 2" Extended Rear Shock Mounts Silverspeed Brakes, Suspension, Chassis 7 01-06-2016 04:53 PM
Rear shock top mounts rick s Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 08-12-2015 12:32 PM
