Old 01-19-2019, 09:56 AM   #1
TommyW
TommyW's Avatar
Drives: '13 Whiteout
Opinions on Trac Control off for Autocross
I'm doing my first AC next week and am wondering what you guys do as far as Trac Control. On the tracks I use the VSC mode as the tracks I drive are fast (Big Willow, Laguna). I was thinking pedal dance mode for AC? Maybe best to start in VSC first and review?
Thoughts?
Old 01-19-2019, 10:29 AM   #2
FastWhite
Drives: Subaru BRZ Limited M/T
I will only speak for myself so take it all with a grain of salt. If you leave traction on you will notice that it will kick in constantly. I usually press my traction off button for 10 seconds.
Locally I do fine with that set up. My car is STX. Prepped. I have run using the pedal dance, but every now and then depending on how bumpy the course is I will activate ice mode.
I read somewhere that ice mode, a maintenance mode, takes you down to one channel for ABS. Pressing the traction control off for 10 seconds you still have four channels. So if one wheel spins ice mode is not activated.
When I bought my first BRZ, the tech rep said to hold it for 10 seconds and not three seconds as per the manual. I have no corroboration that that this is true. But it all works for me.
FastWhite is offline   Reply With Quote
Old 01-19-2019, 10:35 AM   #3
strat61caster
strat61caster's Avatar
Three second press on the left button, two yellow lights on the dash and go. Championships are won with the regular TC off mode.
Experiment once you get some experience under your belt, autox is hard, focus on driving the course well.
ineedyourdiddly
Old 01-19-2019, 10:46 AM   #4
TommyW
TommyW's Avatar
I understood that at 25 mph it automatically comes back on if needed?
Old 01-19-2019, 11:22 AM   #5
FastWhite
I’ll experience the slip light coming on but not activating traction control.
Old 01-19-2019, 12:14 PM   #6
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
That's the short press. The 3sec press that lights up both yellow lights does not come back on.
Old 01-19-2019, 12:15 PM   #7
cjd
cjd's Avatar
Drives: 2017 BRZ
1.5G I think does that.
I use 3sec press. No issues left-foot braking, so it's the place to start. Any TC on is obnoxious as heck on an autocross course.
I've experimented with pedal dance and have horrible results with ice mode... though running no ABS was also causing single wheel lock in the same spots - course, surface, technique probably all responsible in part. I spent last year really focused on braking technique, so will experiment again with PD mostly because its a curiosity.
Old 01-19-2019, 12:20 PM   #8
BlueWhelan
BlueWhelan's Avatar
Drives: 2013 Blue Subaru BRZ. 6 Spd manual
When I do AC I use the 5 sec. press and go. Never had TCS intrude, never needed the ABS to behave differently.
If on a short course, TCS OFF works perfectly well.
BlueWhelan is offline   Reply With Quote
Old 01-19-2019, 01:22 PM   #9
Racecomp Engineering
Long press is preferred over pedal dance for auto-x in our experience (and many others).
- Andrew
Old 01-19-2019, 01:53 PM   #10
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I haven't autocrossed one of these in.. oh 5 years? but I just did the long press as well.
Same at the track at a minimum. The car sucks in VSC sport at the track.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 01-19-2019, 02:06 PM   #11
strat61caster
3s is longer than you think it is.
Long press is probably a better way to describe it. Two lights good, one light that says Trac off is the 25mph get out of snow mode that you don't want. Hold the button until you see the second yellow light.
Pedal Dance is neat if you're good on the brakes and great at judging a corners speed perfectly without ever driving it, bad at either and you'll blow a corner and lose a ton of time. VSC in the first series of cars is crap, there's some posts about it being much improved in the newer cars, but whats the point of autocrossing if you're not going to send it into a corner at 12/10ths without a safety net?
ineedyourdiddly
Old 01-19-2019, 02:06 PM   #12
ZionsWrath
Thanks
ZionsWrath's Avatar
IMO what is the point of "off road" driving if not to learn? How much can you learn with systems on?
My 2013 had severe intervention, even with the long press. When I finally did pedal dance it was like magic. That's not to say you will be faster, but you might learn more.
To each their own, but i will never go to a track event with traction control on again, if i can help it.
Old 01-19-2019, 02:57 PM   #13
TommyW
TommyW's Avatar
Great info thank you all. Looks like 3-5 sec TC off button. Will start there. Was at my private skid pad a few days ago with the rain and used pedal dance and had a blast. Will try the other method though as suggested.
Old 01-21-2019, 09:59 AM   #14
jtmroczk
Drives: C-Street FR-S
Ok, this makes sense of everyone’s opinions a little better...
I had an early 2013, and Pedal Dance was required for that car otherwise any form of traction control would lead to a loss of power and/or understeer.
I’ll have to try again with the new 2018
Thanks everyone
jtmroczk is offline   Reply With Quote
Trac control and ABS lights? soupsayshi Electronics | Audio | NAV | Infotainment 1 10-25-2017 02:03 AM
Abs/trac light Hmm13714 Southern California 0 08-28-2016 04:42 PM
Another ABS and Trac control thread.. nickmerronesucks DIY (Do-It-Yourself) Guides 6 10-22-2015 02:56 PM
CEL + TRAC light... seven Issues | Warranty | Recalls / TSB 7 02-22-2013 10:52 PM
Question about VSC and Trac? Liquidsnake Scion FR-S / Toyota 86 GT86 General Forum 1 04-23-2012 11:24 PM
