Drives: Black BRZ
18x9.5, Meaty tires, and Autocross/Track Days
It seems to be a bit of a hit or miss after going through the "meaty tire" thread. Some say they have rubbing at full lock, others not so much.
Just wanting to check in with 86 owners who have this setup and whether you ran into excessive rubbing/bumping (bumper tabs, inner liner etc.) during autocross and/or track days. (Note: please let's not turn this into another "but-wider-contact-patch-doesn't-equal-more-lateral-grip, it's-the-tire-compound-that-matters" pissing contest) ![]() Thanks for the feedback. |
#2 | |
Country Boy 4 Life
If you will rub or not depends on the offset of the wheels, the suspension mods you have, and the tire you choose. To run 18x9.5 wheels with a higher offset than +38 you will need coilovers. (you may need +35 offset wheels with drop springs) You will need camber front and rear. 235/40/18 have been known to fit on +38 wheels on stock suspension. 245/35/18 is a great size tire, fits without issues and is OEM diameter. 255/35/18 is the widest that fits normally without rubbing. 265/35/18 fits, but will rub on the bumper tab. (till its gone or till you trim it) Those are basically the parameters.
I LIKE TIRES! |
#3 | |
Drives: Black BRZ
Yes, 255's would be it as I was already thinking. It's just that in the other "meaty tire" thread it seemed some were saying they have rubbing issues with 255's and I'd imagine - as you also already alluded to - is due to alignment settings and wheel offset. And, yes, this would happen with a set of coilovers for sure. |
| guys with meaty tires and big power, 17x8 vs 18x9.5? | brz11b | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 15 | 04-21-2021 03:36 PM |
| FS: Hoosier A6 Track/Autocross Tires | Techfl3x | Wheels and Tires | 1 | 09-05-2017 12:37 PM |
| Looking for 17x9 Autocross Track wheels and tires | paintdude258 | Want-To-Buy Requests | 2 | 03-17-2016 07:30 PM |
| Rotating Directional Tires for track and autocross | RMP | Tracking / Autocross / HPDE / Drifting | 7 | 12-03-2014 12:26 PM |
| F/S Enkei RPF1 5x114.3 18x9 +35 18X9.5 +38 with track tires | SsmoothyMonster | Wheels and Tires | 17 | 09-24-2012 01:52 AM |
