Old 01-14-2019, 11:36 PM   #1
maslin
Benz Tech
Drives: 2017 BRZ Premium
Rear Camber with 1” Drop
It seems this topic has been covered multiple times through the years. But nothing recent and I’d like some input.
New (to me) ‘17 BRZ, 5000 miles. Picked it up 3 weeks ago bone stock.
17x8 +40 with the original 215s, I’ll be going up to a 225 or 235 when the weather clears up.
Just installed some used Eibach Pro Kit springs from a member on here. Drop is nice and even, just shy of an inch. Threw it on the rack today and the rear camber is rough.
I have SPC bolts for the front, looks like I should be shooting for -1.5 front camber? Assuming I need rear LCAs to pull the camber back in, -1.3? Moog RK100136 appears to be the same as SPC, $180 vs $215 for the pair on Amazon.
Rear toe I’ve been seeing 0.10* per side, 0.20* total, so that’s where I went.
Front toe I set to 2 minutes toe in unpressed, should be right at 0* pressed. I think I want a bit more toe out, it feels a little light and vague. 22 minutes toe out was nice and heavy, definitely too far the other way though.
So am I heading the right direction? Ignore the red, green and 172 chassis at the top, our machine is brand specific. Also note the specs are in degrees and minutes, not decimals. 0*6’ is 0.10* -0*30’ is half a degree negative camber.
maslin is offline   Reply With Quote
The Following User Says Thank You to maslin For This Useful Post:
Tristor (02-13-2019)
Old 01-15-2019, 04:26 AM   #2
mkodama
86 Challenge
Drives: 2017 BRZ
I used the SPC front camber bolts with crash bolts, and SPC rear camber arms. Front camber maxed out around -1.8, and I set rear camber to match. Rear toe was set on the toe-in side of the stock specs. I ended up going this way on my 2017 car because with stock rear camber I was getting oversteer both on and off throttle, which was hurting track and street confidence.
I’d say the right direction depends on how the car feels to you on the track.
mkodama is offline   Reply With Quote
Old 01-15-2019, 09:39 AM   #3
maslin
Benz Tech
The front felt better at 22’ toe out, obviously that’s way too far. 4’ in is wrong, it feels like a E class.
The rear is off over bumps, need to get the camber fixed before tuning in the toe. LCAs are on the way, gotta love new cars.
Old 01-25-2019, 12:29 PM   #4
maslin
Benz Tech
In case anyone is keeping up, or searches this out. I'm going out on a limb and saying the Moog RK100136 is the same as the SPC kit. $170-180 shipped on Amazon for 2 kits. SPC combo is ~$215 at various sources.
Old 01-25-2019, 12:49 PM   #5
wparsons
wparsons's Avatar
I'm running 0 front toe, 1/16" total rear toe in (not sure on the conversion to degrees). -3.2*F camber and -2.4* rear camber.
The camber curve in the rear is better than the front, so ideally you'll have more front camber than rear.
Don't know anyone that felt the need for toe out up front for daily driving, but you do you.
flickr
Old 01-25-2019, 01:02 PM   #6
norcalpb
norcalpb's Avatar
Yes the following arms are just slotted OEM arms:
Moog
Whiteline
SPC
Superpro
Eibach
Although some will have poly bushings while others have cross axis bushings. I wish I did superpro (I have whiteline) because they are blue and have a sweet combo deal with their adjustable toe arms.
The Following User Says Thank You to norcalpb For This Useful Post:
Old 01-25-2019, 01:19 PM   #7
churchx
churchx's Avatar
Drives: 2014 GT86
norcalpb: add to that list Eibach.
The Following User Says Thank You to churchx For This Useful Post:
norcalpb (02-13-2019)
Old 01-25-2019, 01:21 PM   #8
maslin
Benz Tech
I'll set the front toe to 0 as well. Always treated me well on my 240sx (back in 2004 )
Amazon only sent one LCA, the other shows Prime shipped, delivery Feb 26th. Must be coming on the slow boat. Thanks Amazon.
wparsons (01-25-2019)
Old 02-12-2019, 03:21 PM   #9
maslin
Benz Tech
"Moog" rear LCAs, no rear toe bushings. SPC 14mm bolts in the front lower hole, no crash bolts.
Need to play with some spacers and get properly sized tires. Much happier with how it looks and handles regardless.
The Following 3 Users Say Thank You to maslin For This Useful Post:
Leonardo (02-12-2019), norcalpb (02-12-2019), Tristor (02-13-2019)
Old 02-12-2019, 07:30 PM   #10
Turbo
Drives: FR-S Turbo
Are those alignment numbers measured with or without you in the car?
Turbo is offline   Reply With Quote
Old 02-12-2019, 10:27 PM   #11
maslin
Benz Tech
Empty, as I’ve been doing them for 15 years.
I understand the argument for simulating the weight, the brand I work under does not specify any weights, so we don’t have any.
Haven’t figured out how to do the alignment from the drivers seat, I have a feeling I’ll be out of a job once those days roll around.
Old 02-12-2019, 10:38 PM   #12
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
You could always just put an approximate amount of weight on the driver floor board.
The Following User Says Thank You to NoHaveMSG For This Useful Post:
Turbo (02-13-2019)
Old 02-13-2019, 09:37 AM   #13
Turbo
Drives: FR-S Turbo
Or maybe have one of the other techs sit in the car as you do the alignment, or have them do the alignment while you sit in it?
The shop I went to for my track alignment was very insistent that I be in the driver seat and have the rest of the car in the same condition I track it in before starting my alignment.
The Following 3 Users Say Thank You to Turbo For This Useful Post:
new2subaru (08-01-2019), Tristor (02-13-2019), wparsons (02-13-2019)
Old 02-13-2019, 10:33 AM   #14
wparsons
wparsons's Avatar
Can-alignment? Sounds like Scott
flickr
The Following 2 Users Say Thank You to wparsons For This Useful Post:
new2subaru (08-01-2019), Turbo (02-13-2019)
Rear camber crazy from .75" drop Norinradd Suspension | Chassis | Brakes -- Sponsored by 949 Racing 40 11-07-2016 08:56 PM
*FREE alignment* with Purchase and install of Front Camber / SPL Rear Camber Arms! Corner3garage Southern California 188 04-24-2015 02:10 PM
Drop and camber. WillBRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 23 02-09-2014 07:31 PM
*FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! Corner3garage Mechanical Maintenance and Tools 6 10-31-2013 04:40 PM
