Drives: '18 86 (Asphalt)
Front Tow Hook mounting threads
I just got a front license plate tow hook relocation kit. However, it doesn't seem to thread right. It feels like it's threading in, but I can easily pull it out. To check this, I also screwed in the tow hook that came with the car. It also wiggles a little bit and is easily pulled out. Am I just not screwing it in correctly? or is the threading in the car's front tow hook receiver defective?
Drives: 2017 BRZ
Which kit did you get? I got the kit from Grimmspeed and it's completely solid. Maybe you got a kit for a different car that doesn't have the right threading?
I got the TurboXS kit. I got it because it fits the 17+ 86 bumper. http://www.ft86speedfactory.com/turb...2013-ft86.html
But also the tow hook that came with the car in the trunk doesnt seem to thread correctly, I can pull it off easily. I dont know if its the threading or i'm not screwing it in correctly. |
#4 | |
Drives: red 2014 FR-S
try putting the tow hook in one of the rear mounts and see if it screws in correctly. |
Drives: 2019 Toyota 86
Youre just not aligning it properly. I installed one a couple a days ago and had exact same issue, took me damn 20 minutes to figure out hoe to thread it in properly. If it helps, from the way I was trying to thread it in (you might be doing it differently/at a different angle) I had to very slightly change angle so the non-threaded end moved towards the center of car (my right ). Just keep trying until it doesnt come out when you pull on it. Finish up tightening with a wrench
Sent from my LM-Q610(FGN) using Tapatalk |
He's got this.
Drives: 50th Anni BRZ
I'm having issues with my Perrin relocation kit. It felt like it went in correctly and I was able to make it hand tight. The problem is the instructions say to tighten it to 50 ft-lbs, I used my torque wrench but it would not get any tighter, it just kept spinning with the same resistance. I have I done something wrong?
It felt secure enough so I attached the plate but now I can use the plate to spin the whole assembly.
Don't worry, I'm certified... promise.
#7 | |
#8 | |
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
Righty tighty, Lefty loosey
#10 |
He's got this.
Well it seems like I just didn't realize how many times I had to spin the thing. Removed it, threads were ok, tried the stock toe hitch, that went in fine and tightened (much sooner I might add), reinstalled the perrin piece and kept spinning with no increase in resistance until... it stopped.
Guess I am less inclined to car maintenance than I throught.
| Tags |
| tow hook |
| DIY: Center Mounting the Front License Plate WITHOUT DRILLING | Neurytic | DIY (Do-It-Yourself) Guides | 28 | 05-14-2018 05:37 PM |
| WTB: Need front seatbelt lower mounting hardware | skylinekin | Want-To-Buy Requests | 0 | 04-02-2018 06:33 PM |
| FS: Front Tow Hook plus front and rear covers | imartisfrs | Exterior Parts (Aero, Lighting, Etc.) | 8 | 08-05-2015 04:15 PM |
| How are you guys mounting front license plates? | SubaSteveDDS | Cosmetic Modification (Interior/Exterior/Lighting) | 19 | 07-30-2015 08:07 PM |
| APR Front splitter, mounting? | mrk1 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 03-26-2014 11:58 PM |
