Old 12-31-2018, 12:56 PM   #1
msaikhan
Drives: frs
valenti tail lights wiring switched
I got some non sequential valentis, but the signal and brake lights wiring is switched. The brake lights turn on when i signal, and signal lights work as running lights and brake lights. Anyone had this problem?
im going to swap the 2 wires for signal and brake, and hopefully that fixes it. But im not sure if it will also fix the running lights...
msaikhan is offline   Reply With Quote
Old 12-31-2018, 07:29 PM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
i recall seeing that issue with jdm-sourced tail lights. there was a how-to for a different set of tails to do the same thing
Old 12-31-2018, 08:01 PM   #3
Brink
Drives: 2017 BRZ
I got some Spyders and they came with instructions for swapping some wires like this depending on which market the lights were sourced from/installed in. As I recall they sold the lights with the wiring done in one of two different ways depending on which market they were sold in, and the instructions told which wires to swap if you were in the other market.
Brink is offline   Reply With Quote
FS: OEM Tail lights and Valenti Clear Tail lights x1UP Exterior Parts (Aero, Lighting, Etc.) 16 01-28-2017 01:19 PM
Valenti / Lexon / Tom Tail lights, Winjet Headlights, Front Bumper lights and Mirrors Speed Element Exterior Parts - Lighting 224 12-06-2016 03:07 PM
NEW EXCLUSIVE Valenti Tail lights, Winjet Headlights, Front Bumper lights and Mirrors Speed Element Northern California 34 01-14-2015 06:32 PM
