Old 12-26-2018, 05:08 PM   #1
majixmatrix
BRZ Wannabee
majixmatrix's Avatar
Drives: 2013 Limited BRZ
Flex Fuel OFT Tune with Upstream O2 Sensor?
I recently purchased a used Delicious Tuning Flex Fuel kit and it says to utilize the downstream O2 sensor during installation. I find this odd because the upstream sensor is a wideband, and I have a spacer on my downstream O2 sensor in order to pass inspection with my catless header.
Would Shiv be able to write a Flex Fuel tune using the upstream O2 sensor and not the downstream sensor? If the downstream sensor is required, can I leave the spacer installed?
Thanks! Looking to go E85 in the spring along with some other goodies.
majixmatrix is offline   Reply With Quote
Old 12-27-2018, 03:07 AM   #2
steve99
Think your misunderstanding whats happening.
All flex systems and tunes require the front or primary o2 sensor to be in use.
the rear 02 sensor inpt can be repurposed to become the flex fuel sensor input or you can use the evap pressure input on connector A35 pin20 of exu.
Most comercial flex kits will use rear o2 an input for flex however some dont one of these is the OFT flex tune and flex kit. So you should be able to use your deliceous flex kit with oft tune by just doing a little rewiring and send the signal wire to the evap input, you may also need to source the volts and earth as well as some rear o2 connect kits source volt and earh from rear 02 sensor plug.
then you can keep you rear 02 in place and run flex sensor via oft tune.
ecutek can also do this
delicious, flexfuel, oft, shiv
thinking of getting DT stage 2 flex fuel tune, do I need a flex fuel kit? stlgrym3 Engine, Exhaust, Transmission 4 03-23-2018 03:51 AM
Zeitronix Ethanol Content Analyzer and Display Kit Red + Flex Fuel Sensor with Fuel L BRZ_HaVoKx Engine, Exhaust, Bolt-Ons 9 01-15-2017 10:40 PM
My Review of Ace A/350 Header & Delicious Tuning Flex Fuel Kit + Tune tomaszjanczak Engine, Exhaust, Transmission 15 09-26-2016 12:06 AM
Zeitronix Ethanol Content Analyzer and Display Kit Red + Flex Fuel Sensor with Fuel L BRZ_HaVoKx Audio/Visual, Electronics, Infotainment, NAV 4 07-16-2016 07:43 PM
ECUtek Flex Fuel REVOLUTION: World's First Flex Fuel Factory ECU GTR - BRZ soon! Visconti Engine, Exhaust, Transmission 356 05-20-2013 10:36 AM
