Old 12-22-2018, 12:00 PM   #1
pakunodafie
Drives: Toyota GT86
Misfire at Idle? No CEL. Please help video attached!
Hello Guys,
I've experience this since last week, whenever I am in idle, cold startups, parked I hear something. pompp.. pohhhmp poohmp. poohhm. totally random.
Not noticable but still I can feel it. and car vibrates very very little. whenever there is a pohmmp random sounds.
Ive searched in any forums found some answer and said might be a carbon buildup in valves, bad sparks plugs, Direct injection issues, or bad coils.
Here is the similar video.
Car is pure stock, No CEL.
Does anyone experienced this and how did you solved it?
pakunodafie is offline   Reply With Quote
Old 12-22-2018, 12:29 PM   #2
steve99
Could be lots of things.
Can you log misfire counts per cylinder ?
It it only at idle
Is the car 2012 or 2013 model ? has it had ecu reflash for rough idle ?
has car been serviced regularly , has it had upper engine cleaner used at service intervals
https://www.ebay.com.au/itm/1-X-NEW-...UAAOSwP4dazaG-
could be bad fuel, spark plugs coil packs , start of DI injector problems
Old 12-22-2018, 12:46 PM   #3
pakunodafie
Drives: Toyota GT86
It it only at idle
Car is 2014, service regularly, Last serviced last week @90k kms. They put injector cleaner for additional $30.
I don't have a tool to count misfire counts.
I can hear only in idle, parked and drive but not moving. once car is moving it runs perfectly.
Old 12-22-2018, 01:36 PM   #4
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
I hear bad things about dumping injector cleaner in the gas tank. Besides, gas has injector cleaner built into it, so I think you should consider the DI injector seals or something else as a culprit over built up carbon deposits.
Old 12-22-2018, 02:42 PM   #5
pakunodafie
Drives: Toyota GT86
Is that an easy fix? Or need to spend some dime?
Old 12-22-2018, 03:01 PM   #6
Irace86.2.0
I did mine. They weren't hard. Just time consuming. Check my build.
Old 12-23-2018, 06:21 AM   #7
pakunodafie
Drives: Toyota GT86
Great build, If what do you think is the poohmp sounds?
Old 12-27-2018, 07:48 AM   #8
pakunodafie
Drives: Toyota GT86
UP
Old 12-27-2018, 07:56 AM   #9
MCTeeJ
MCTeeJ's Avatar
Drives: 2014 Scion FR-S
Is the sound coming from the engine bay or the exhaust?
MCTeeJ is offline   Reply With Quote
Old 12-27-2018, 03:44 PM   #10
pakunodafie
Drives: Toyota GT86
Noticable in exhaust. but I change my stock to N1, still pohhmp sounds coming.
Old 12-27-2018, 04:13 PM   #11
MCTeeJ
MCTeeJ's Avatar
The car retards a ton of timing on that cold start initial idle. Could result in the noises you're hearing from the exhaust. @steve99 ?
Misfire at Idle RavioliG Issues | Warranty | Recalls / TSB 21 09-29-2019 08:12 PM
Bearing/trans issues. Video attached. DFWFRS Engine, Exhaust, Transmission 1 04-29-2017 02:59 AM
Squirrel noise >1K RPM, Video attached SubieNubie Issues | Warranty | Recalls / TSB 9 11-26-2013 11:11 PM
Idle Misfire/Stumble Nightbringer Issues | Warranty | Recalls / TSB 20 09-18-2013 11:27 PM
ECU replaced. Still has slight misfire, rough idle xomp Issues | Warranty | Recalls / TSB 1 11-01-2012 08:53 AM
