Old 12-19-2018, 11:08 AM   #1
l3ooml3al2al3a
Drives: 2013 Toyota FT86
Wedssport SA-10r 18xf8.5, r9.5 +45
I guys I'm new around here. I just got Weds in 18x8.5 front and 18x9.5 rear both are +45 with pilot sport 4 225/40 for 4 wheels (you can see a little bit stretch in the rear wheels). The fitment with completely stock suspension seems good to me. Still, I'm going to get new tire in a couple of weeks and planing to get the pilot sport 4 with 225/40 front and 235/40 rear. Here come the question. Will I get rubbing problem in the rear with wider tire and stock sus ? Can I go for 245/40 ? The tire shop said I might get the problem with 245 with no camber adjustment, but I doubt that will be the case.
l3ooml3al2al3a is offline   Reply With Quote
Old 12-20-2018, 10:57 AM   #2
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
The rears will fit no problem even up to 255. It's the front you need to worry about. Since your offset is +45, the tire will sit pretty close to the spring perch, which is what you would be rubbing on.
However, split offset will cause more understeer, but will be fine if that is what you're looking for.
You can probably do 235 all around, add camber bolts to the front to add in negative camber. That would be a cheaper way to do it.
N1rve
Old 12-20-2018, 11:18 AM   #3
l3ooml3al2al3a
Thanks for the answer. I plan to get 225 front and 235 or 245 rear, but what do you mean by split offset sir. I'm unfamiliar with this term.
Did some research and I got it now
Old 12-20-2018, 11:46 AM   #4
N1rve
N1rve's Avatar
I couldn't think of the proper word but it's more like split sizing in the tires.
N1rve
Old 12-20-2018, 11:47 AM   #5
Vital
Drives: 2015 BRZ
I think the term you are looking for is "Staggered"
Vital is offline   Reply With Quote
The Following User Says Thank You to Vital For This Useful Post:
Leonardo (12-20-2018)
Old 12-20-2018, 12:18 PM   #6
Leonardo
Country Boy 4 Life
Leonardo's Avatar
OP, your car looks amazing!
So, I had a few different staggered setups. The larger the difference in tire width, the worse the car will drive. I would think about 245/35/18 all around. Or, keep your 225/40 front and get 235/40/18 or 245/35/18 rear. You could also run 245/35/18 front and 255/35/18 on the rear.
IMO, a 225/40 255/35 stagger is not what you want.
Camber bolts are good, but with only about 6mm of clearance, you won't be able to add much negative camber without adding a spacer or switching to coilovers. (I would get two more 18x9.5s for the front if you get coilovers. Then run the same 255/35 tire front and rear)
Good Luck!
I LIKE TIRES!
Old 12-20-2018, 12:35 PM   #7
N1rve
N1rve's Avatar
That's the $10 word of the day!
N1rve
The Following User Says Thank You to N1rve For This Useful Post:
Vital (12-20-2018)
Old 12-20-2018, 10:25 PM   #8
l3ooml3al2al3a
I will get coils eventually. Was going with Tein Flex-Z with my previous Mazda car and I quite like the smooth riding feel. Any other options ? Now I have RSR-best I or Cusco spec A as alternatives.
Wedssport SA-72r 18x9.5 +45 Kendallkab Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 12-13-2018 12:18 AM
WedsSport SA-10R SoSoCrispy Wheels and Tires 0 05-20-2018 08:25 PM
WedsSport RN-05M 18x8.5 + 45 (PSS 225/40/18 All Around) Veloist Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 12-07-2016 02:31 PM
WEDsSport SA-15R 3W Distributing Wheels and Tires 7 07-22-2014 03:00 PM
