Old 12-18-2018, 06:28 PM   #1
Jeffrayylmao
Drives: 2015 Asphalt Gray FR-S
Scosche MagicMount Pro Charge
Hey guys, thinking of picking up a Scosche vent phone holder with wireless charging, however I have no idea where to run the cable with it looking good. Any ideas?
Jeffrayylmao is offline   Reply With Quote
Old 12-18-2018, 07:13 PM   #2
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
I have a different mount now, but I simply shaved off the corner of the instrument cluster hood trim, and ran a 10' cable through the dash to the second power outlet in the glovebox. Also ran one down the center console so a passenger can pull it out and use it when needed. Otherwise it tucks back in until only the end bit is sticking out. (Carved a little sliver out next to the power point for this cord too.)
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
Old 12-18-2018, 11:23 PM   #3
Jeffrayylmao
Originally Posted by Stang70Fastback View Post
-snip-
That's a cool solution! Wondering if theres anything else I have to do without cutting my trim though
Also, I'm pretty sure it would be the little 10v car charger thing instead of a USB... thinking of mounting it on the middle air vents above the headunit, so maybe something I could do with the 10v plug in the glove box(?).
Old 12-18-2018, 11:42 PM   #4
Stang70Fastback
A.K.A. Starlord
The gauge cluster hood is easily replaceable, and isn't expensive, so it's not like you're permanently modifying your car I don't like doing any permanent modifications either.
2017 brz trapezoidal opening - Scosche SU2032B Dash Kit - any alternatives? dma550 Electronics | Audio | NAV | Infotainment 14 12-18-2018 01:53 PM
Charge Air Cooling VerusEric Engine, Exhaust, Transmission 23 01-06-2017 03:28 PM
Do you feel in Charge? LS13 Off-Topic Lounge [WARNING: NO POLITICS] 0 03-28-2014 09:01 PM
Scosche touchscreen A/C controller DIREWOLF Electronics | Audio | NAV | Infotainment 46 03-30-2013 07:42 PM
ECU Charge??? DBacon1052 Issues | Warranty | Recalls / TSB 12 09-18-2012 11:53 PM
