Old 12-16-2018, 06:20 PM   #1
CTOWN360
Drives: 2013 FRS
Help!!!
Had to change the engine in my 2013 FR-S. I got engine in and put a new battery in also. When I went to start the car I get all the normal lights and dings but the car will not turn over. I tested the starter and it checks good. I checked the inhibitor relay and I get power to it when the key is in the start position. Same with the starter relay. I’ve checked all the fuses and they are fine. Any help is appreciated.
CTOWN360 is offline   Reply With Quote
Old 12-16-2018, 07:22 PM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Does it crank at all?
If yes - is there gas in the car? Spark plugs?
If no - Crankshaft / cam position sensor, did you check them? Did you put the engine in, or did someone else?
DarkPira7e is online now   Reply With Quote
Old 12-16-2018, 07:33 PM   #3
humfrz
You might try putting a big wrench on the crankshaft pulley bolt, and turning it, to make sure the engine isn't frozen -
If it's a MT, did you check the clutch switch thing?
humfrz
DarkPira7e (12-16-2018), scion fr-s (12-17-2018)
Old 12-16-2018, 08:06 PM   #4
CTOWN360
Drives: 2013 FRS
It doesn’t turn over at all. I put the engine in. I will check both. Thank you
Old 12-16-2018, 08:07 PM   #5
CTOWN360
Drives: 2013 FRS
humfrz
Engine will spin with the crank bolt.
The Following User Says Thank You to CTOWN360 For This Useful Post:
humfrz (12-16-2018)
Old 12-16-2018, 11:50 PM   #6
humfrz
Does the starter even "click"?
Even though the battery is "new" will it pass a load test?
Are the battery connections good and clean?
You might try grounding the negative terminal to the frame with some jumper cables?
humfrz
Old 12-17-2018, 12:20 AM   #7
scion fr-s
scion fr-s's Avatar
Drives: 2017 PP BRZ
See if the radiator fans spin by hand!
scion fr-s is offline   Reply With Quote
Old 12-17-2018, 01:18 AM   #8
DarkPira7e
DarkPira7e's Avatar
Check all grounds, the starter may not be grounded. You said you checked all fuses so ecu fuse isnt the culprit, and if it's not cranking at all, probably isn't a sensor
Old 12-17-2018, 11:04 AM   #9
CTOWN360
Drives: 2013 FRS
humfrz
No I have not done a load test on the battery other then sticking in my other car and having it start just fine. There is no click. i have checked the signal wire going to the starter when it is in the start position and it is not getting power.
Old 12-17-2018, 11:05 AM   #10
CTOWN360
Drives: 2013 FRS
I made sure to hook them all up but maybe they need better cleaning. will check again.
Old 12-17-2018, 01:09 PM   #11
CTOWN360
Drives: 2013 FRS
UPDATE-- Things i have tried.
1) out the key in the start position and move the gear shift from park to neutral. Nothing
2) checked power to the starter from the batter. Good. Checked for power to other wire while in the start position.. Nothing.
3) pulled the inhibitor relay. put the car to the start position and one off the 4 wires gets power.
4) pulled the starter relay and same results as the inhibitor relay.
5) pulled the crank shaft position sensor. Did an OHMs check.. checks good.
humfrz (12-18-2018)
Old 12-18-2018, 10:41 PM   #12
humfrz
Update?
humfrz
Old 12-18-2018, 11:56 PM   #13
LunarStorm86
Drives: 2016 FR-S RS2.0
does the instrument cluster show that its in park or neutral when you have it in either? you say you swapped engines, double check the connectors at the back of the engine where the trans section ties into the engine harness. could be connector not snapped in all the way. I doubt you blew a fuse swapping an engine unless you dropped a tool across both terminals while they were still connected. even then, I doubt it. check the connectors like I said and get back with us.
LunarStorm86 is offline   Reply With Quote
Old 12-19-2018, 08:47 PM   #14
CTOWN360
Drives: 2013 FRS
That connector was the first one I looked at. Yes it shows park and neutral and changes as I shift it.
