Old 12-10-2018, 06:53 PM   #1
scion fr-s
scion fr-s's Avatar
Drives: 2017 PP BRZ
Battery
Hello guys/gals I am wondering if anyone has modified there factory battery terminals? I just picked up an Odyssey battery!
scion fr-s is offline   Reply With Quote
Old 12-10-2018, 06:55 PM   #2
scion fr-s
scion fr-s's Avatar
Drives: 2017 PP BRZ
The odyssey battery is the PC925 and the terminals i bought were SAE 3217-0006
https://www.summitracing.com/parts/o...4aAmYKEALw_wcB
Old 12-10-2018, 07:47 PM   #3
humfrz
Well, I haven't had to replace my car's battery yet, but when I do, I reckon I'll buy one that fits -
humfrz
scion fr-s (12-10-2018)
Old 12-10-2018, 08:04 PM   #4
Grady
Grady's Avatar
humfrz
That sounds to easy. When mine goes out I will retrofit it with a super light weight fuel cell that runs on unicorn farts. Total weight is -2lbs, hope it does not affect the handling?
The Following 3 Users Say Thank You to Grady For This Useful Post:
humfrz (12-10-2018), scion fr-s (12-10-2018), Tcoat (12-10-2018)
Old 12-10-2018, 08:07 PM   #5
It will dive into left turns but I have heard good things on the unicorn fart tech.
humfrz (12-10-2018), scion fr-s (12-10-2018), Spuds (12-10-2018)
Old 12-10-2018, 08:17 PM   #6
scion fr-s
scion fr-s's Avatar
Drives: 2017 PP BRZ
Yea, I am thinking of a way to retrofit it.
Old 12-10-2018, 08:25 PM   #7
Unbolt the wrong posts and bolt on the right ones?
Old 12-10-2018, 08:47 PM   #8
scion fr-s
scion fr-s's Avatar
Drives: 2017 PP BRZ
The electrical connector on the negative side is making me think otherwise.
Old 12-10-2018, 08:49 PM   #9
scion fr-s
scion fr-s's Avatar
Drives: 2017 PP BRZ
https://honda-tech.com/forums/honda-...-stop-3213741/
Something like this
Old 12-10-2018, 08:59 PM   #10
I have no clue what that thing they have hooked up to it does but you can get the 925 with normal posts so I don't see why it isn't a straight swap.
You have the option of either when you order it https://www.batterymart.com/p-odysse...5-battery.html
Old 12-10-2018, 09:00 PM   #11
humfrz
I have a hint for you. Right now, before you start switching posts and connectors, etch a "+" on the side of the battery near where the "+" pole of the battery really is - so as when, in the heat of post conversion/confusion, you don't hook up the battery backwards...-
you can thank Bubba fer that hint
I remember, back in the day, not all automotive electrical systems were negative ground, some were positive ground. And to add to the confusion, some automotive electrical systems were 6 volt and some 12 volt (and yes, @Tcoat, some military electrical systems were 24 volt).
Now, talk about nipple confusion -
humfrz
Old 12-10-2018, 09:06 PM   #12
humfrz
The polarity comes molded on the battery nowadays. The tech has advanced considerably over the eons since your military service.
humfrz (12-10-2018), Spuds (12-10-2018)
Old 12-10-2018, 09:14 PM   #13
scion fr-s
scion fr-s's Avatar
Drives: 2017 PP BRZ
humfrz
Do you know the purpose of the electrical connector that connects to the negative side?
Old 12-10-2018, 09:19 PM   #14
Wait. You mean the one on our cars not that contraption on the Civic? It is just ground cables. Bolt it back on, change the posts and clamp the cables on.
Optima Battery Size that fits TRD Battery Clamp? golden86child Engine, Exhaust, Transmission 7 03-26-2018 07:12 PM
Battery Brace touched Positive Battery terminal, car won't start!! 7m28 Issues | Warranty | Recalls / TSB 21 09-24-2017 01:55 PM
FS: KC Machine lightweight battery mount with Shorai battery and charger toeout Engine, Exhaust, Bolt-Ons 4 04-23-2017 01:07 AM
Help! Battery died, charged battery now getting all sorts of error codes! jermyzy Issues | Warranty | Recalls / TSB 12 11-25-2015 01:35 PM
Shorai Lightweight Battery and KCMachine CNC Machined Battery Tray Package KCMachine Brakes, Suspension, Chassis 111 10-08-2014 09:26 AM
