Old 12-09-2018, 02:30 PM   #1
pakunodafie
Drives: Toyota GT86
CLANG sound Please help!!
Clang sound like metal to metal banging each other, Sound coming under the car.
Totally random sometimes when I turn right or after speed bumps it's like I am draging a trashbin under my car, I already checked undercarriage no panels are loose. Heatshield is ok.
Please listen and see the video:
https://www.dropbox.com/s/6ntx911o8f...1_1_1.mp4?dl=0
Happened only twice.
1st - speed bump - Slow approach 5-10kmph after bump.
2nd - Turning right - 30kmph speed.
Please help which possible issue I am facing now?
pakunodafie is offline   Reply With Quote
Old 12-09-2018, 03:45 PM   #2
humfrz
Hello pakunodafie and welcome to the forum -
If it only happened twice, I wouldn't worry about it -
However, if you can't let it go, I'd suggest you check and make sure the wheels are on tight, then check the brakes. Maybe your brakes pads are worn down to the wear indicators or a caliper is lose or sticking.
humfrz
Old 12-09-2018, 03:57 PM   #3
pakunodafie
Drives: Toyota GT86
humfrz
Thanks buddy, Pads are fresh last month, Ill reseat them later and I am suspecting is heatshield might be loose a little bit, maybe hard turn and after speedbumps heatshield touch the drive shaft. and sometimes when cruising 100kmph redl ining the car there's some rock rumble under the car, might be a panel.
Some says its CV Axle. but need to check later.
Old 12-09-2018, 05:41 PM   #4
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
Just an FYI, if our cars go up a slope at an angle and one of the wheels gets free it produces a funky clank sound
Old 12-09-2018, 11:21 PM   #5
pakunodafie
Drives: Toyota GT86
Does it sound like in the video?
Old 12-09-2018, 11:46 PM   #6
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
That sounds different, but hard to really tell because the low quality of the video. Can you point towards the section of the car? front/rear/left/right?
Old 12-10-2018, 04:13 AM   #7
pakunodafie
Drives: Toyota GT86
Sounds coming from rear middle of the car.
Old 12-10-2018, 05:46 AM   #8
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
Does it also happen when you suddenly accelerate?
I'm thinking could be the 2 piece drive shaft / diff .. ?
Show dealer the video and point out the noise you're referring to?
Old 12-10-2018, 06:48 AM   #9
pakunodafie
Drives: Toyota GT86
Accelerating from 0 - 60 is smooth, when reached 100kmph and 7k rpm a weird noise coming under the car, sounds like small rocks chirping down the car.
But the clang sound happens randomly sometimes after speedbumps or after turning right.
Old 12-10-2018, 11:38 PM   #10
pakunodafie
Drives: Toyota GT86
I sent it to the dealership, They cannot replicate the sound. So they did not fix anything.
I have 2 sounds issues.
1. Clang clang noise when turning or after speedbumps(totally random)
2. Random noise shows up like I am dragging a trashbin under my car.
Old 12-11-2018, 12:00 AM   #11
humfrz
Did you check the CV joints, like you mentioned?
Is the rear axle nut tight?
humfrz
Old 12-11-2018, 12:17 AM   #12
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Is the car stock? If not, what modifications are there?
Also, has there been any maintenance activities just before this started happening?
Old 12-11-2018, 07:50 AM   #13
Brz_racer
Drives: Subaru BRZ
Well you can rule out CV Joint RWD cars do not have them. It's most likely a loose rattling panel. Also keep in mind this car makes sounds you have likely never heard due to the lack of sound deadening.
Brz_racer is offline   Reply With Quote
Old 12-11-2018, 08:50 AM   #14
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
Is the exhaust rattling on something?
BigTuna is offline   Reply With Quote
Odd sound at 6k RPM dutchman1 Engine, Exhaust, Transmission 25 01-02-2017 04:41 PM
Does this sound deal sound decent ? awhatzable Scion FR-S / Toyota 86 GT86 General Forum 29 11-21-2015 10:02 AM
Drone (Worn Wheel Bearing SOund) Sound From Rear qbzee007 AFRICA 8 11-14-2014 01:04 AM
South Sound Summer Jam 2013 | 8.18.13 | South Sound Speedway RussellM Northwest 13 09-05-2013 09:57 AM
Best sound BAE Engine, Exhaust, Transmission 4 09-30-2012 09:30 PM
