Old 12-08-2018, 12:59 AM   #1
Salim
Drives: 2012 Toyota GT86
86 gear lever play
Hi. The gear lever on my 86 has a lot of side to side movement when in gear. It moves about an inch and a half on each side in all gears. Any advice on how to rectify this issue
Salim is offline   Reply With Quote
Old 12-08-2018, 01:06 AM   #2
Ultramaroon
not playing cards
Ultramaroon's Avatar
Originally Posted by Salim View Post
Hi Guys. The gear lever on my 86 has a lot of side to side movement when in gear. What do I need to do to resolve this?
Do you have any trouble getting into first or second?
Can you rotate the gearshift even the slightest bit about its vertical axis?
You never answered my questions in the first place.
JohnJuan (12-11-2018)
Old 12-08-2018, 02:02 AM   #3
Salim
Sorry. Couldn’t find the original post. Getting into second is a bit difficult when it’s cold. It does not rotate
Old 12-08-2018, 02:37 AM   #4
Ultramaroon
not playing cards
Do you mean that it vibrates excessively, or that it's loose and wobbly?
The ability to get it into first and second gear is important, as is the question of rotation. If neither of those have changed then it points to an issue inside the gearbox itself.
Old 12-08-2018, 03:22 AM   #5
humfrz
Well, you got me confused, old man -
(but, that don't take much - )
So, what's the fix?
humfrz
Old 12-08-2018, 03:12 PM   #6
Ultramaroon
not playing cards
So, what's the fix?
Look at the exploded view of the gearshift parts. I dunno but there ain't much that can go wrong on the outside without affecting alignment between the first and second gear gates, and the lockout plate.
Old 12-08-2018, 03:29 PM   #7
Frankly I don't see how you could have that much movement anywhere inside the tranny and have it still functioning.
Old 12-08-2018, 03:37 PM   #8
humfrz
Salim, if you could post a video, that may help us help you -
humfrz
Old 12-08-2018, 03:38 PM   #9
Ultramaroon
not playing cards
Right? I've never had mine apart. Still can't picture how the thing works.
Old 12-08-2018, 04:05 PM   #10
Audio
Drives: 16 FR-S Raven
STOP PLAYING WITH IT!!!
Audio is offline   Reply With Quote
Old 12-08-2018, 04:41 PM   #11
Ultramaroon
not playing cards
The best image of it that I've seen to date was shot by @VerusEric.
Old 12-09-2018, 01:09 AM   #12
Salim
Can’t seem to get the video uploaded. It’s basically when in gear , if you move the lever left to right it has a lot of travel. So I took it apart yesterday And found that the bushes were worn. Replaced these and the problem is gone
The Following User Says Thank You to Salim For This Useful Post:
Old 12-09-2018, 03:10 PM   #13
humfrz
Thanks for the update.
I don't follow the bolded part, but that's OK.
Glad you got it fixed -
humfrz
Old 12-09-2018, 04:19 PM   #14
Ultramaroon
not playing cards
fake news
Gear lever rattle - fixed sav AFRICA 16 01-30-2020 10:22 PM
STI GEAR SHIFT LEVER (ST35010AS000) unpacking Trap63 DIY (Do-It-Yourself) Guides 50 04-26-2016 06:25 PM
Gear lever rattle Freedom Engine, Exhaust, Transmission 18 11-10-2015 12:17 PM
Ferrari like gear lever ? mashal Scion FR-S / Toyota 86 GT86 General Forum 54 10-20-2015 03:03 AM
Gear lever rattle Freedom AFRICA 0 05-25-2015 05:17 AM
