Drives: 2017 BRZ
Enable TPMS on non-US BRZ
I've got a 2017 BRZ, and here in Canada TPMS is not mandatory so it's not a feature on my car. I know there are aftermarket systems, but given it's included on the US models I'm wondering if there's any way to enable it on the Canadian model (assuming I purchase and install the sensors). Has anyone done this, and if so how?
Sent from my SM-G930W8 using Tapatalk |
Drives: 2016 Subaru BRZ
You'd probably just need a TPMS programmer in order to get it done. The FR-S in Canada had TPMS. I bet the only thing missing from the BRZ are the sensors for the wheels.
On the flipside, is there any way to disable TPMS on American cars?
Senior Misanthrope
#5 | |
Drives: 2017 BRZ
The BRZ does have it installed, the door control and the TPMS are one receiver located on the back shelf. The service wiring diagram confirms this as being a dual function unit on page 252. http://www.ft86club.com/files/BRZwiringi.pdf
I think there is also one in the front behind the radio. Check out page 42 in the same PDF, A30/A64. |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
Though a pressure stick would be far cheaper.
If you walk around and look at the tires, sometimes (not always) you can see a sub pressure situation before it becomes acute. Then you fill it up with air until it gets round again. I know it's daft! It's traditional though.
"I gotta rock." -- Charley Brown |
pessimistic skeptic
TPMS is a safety feature. It only indicates pressure is low when it is a safety concern. It does not help with maintaining the optimal pressure for performance and/or efficiency. It does not show actual pressure and specific tire.
I would add something like this. |
The Subaru scan tool at my local shop can pull both the individual pressures and temps at each wheel through the OBDII port. It would be nice to have on display.
| re-enable cold start on OTS stage 2 plus | Laz84 | Software Tuning | 21 | 08-16-2020 05:04 PM |
| Rear Foglight Enable | Tye300 | DIY (Do-It-Yourself) Guides | 73 | 05-09-2017 01:37 PM |
| Enable DRL?? | peachch | ASIA | 6 | 08-09-2015 04:30 PM |
| NEED HELP!! TPMS light on. with TPMS installed on aftermarket rims+tires | Figo | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 9 | 09-23-2013 08:11 AM |
| Changed to new wheels w/o TPMS, car still thinks I have TPMS sensors? | Ahz | Issues | Warranty | Recalls / TSB | 9 | 11-06-2012 08:25 AM |
