Rear turn signals blinking too fast
I just installed my widebody kit, and the new front bumper has no spots for the oem turn signals and side markers. So I know that the issue is due to the fact that those lights arent connected. Is there a way I can add a resistor into the circuits to fix the flash rate of my rear turn signals? What ohm resistor would I need?
Thanks! |
ProCrastinationConsultant
DO NOT INSTALL RESISTORS ON AN 86!!! load resistors create heat, and unless you want to risk burning your car down to save $20, they are not worth the hassle.
nearly all toyota's have a replaceable turn signal flasher. replace the flasher with an led-compatible version. but you really should install turn signals in the front of the car to stay legal.
| Turn signals flashing too fast after installing TOM's tails | Demotic | Cosmetic Modification (Interior/Exterior/Lighting) | 19 | 10-14-2013 12:15 AM |
| OEM JDM Tail light Blinking Fast | ZC6BRZ | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 06-13-2013 12:32 AM |
| Selling both rear OEM tails with amber LED turn signals | ThaBigUnit | Exterior Parts (Aero, Lighting, Etc.) | 2 | 05-24-2013 02:33 PM |
