Old 11-18-2018, 10:05 PM   #1
DuMa
DuMa's Avatar
Drives: LR BRZ Limited
Anyone else have this issue with Valenti Tails
The issue I'm having is when I tap on the brakes, the passenger LED Bar lights up and is very bright like i remember but the driver side is very dim. It still however lights up. I've had my Valentis for over 3 years and never had an issue but now im not even sure when this started because i obviously never look at my rear end when i am braking. I only noticed it because someone else told me my brake lights appeared to be off on the driver's side.
the parking lights/glowing Bracket LEDS still work however.
DuMa is offline   Reply With Quote
Old 11-19-2018, 06:53 PM   #2
fx1mark
fx1mark's Avatar
Drives: red 2014 FR-S
A simple way to determine if it's the light of something else would be to remove the lights and swap them. just lay them in the trunk. press the brake and see what happens. If the dim light moves over to the passenger side it's a problem with the light. If the problem remains on the drivers side then the problem is the car-probably wiring.
fx1mark is offline   Reply With Quote
Old 11-19-2018, 07:18 PM   #3
humfrz
Check the ground and/or replace the bulb (LED) -
humfrz
Old 11-19-2018, 07:26 PM   #4
norcalpb
norcalpb's Avatar
I’ve noticed aftermarket taillights work for about 3 years and then start to have issues.
WTT: My Valenti tails for '17 stock tails (MD/VA/S. PA areas) PR138 Want-To-Buy Requests 8 02-12-2018 03:57 PM
FS: Valenti RED Tails. Valenti RED 3rd Brake Light. OEM Clear Corners. AngryS13 Exterior Parts (Aero, Lighting, Etc.) 6 08-14-2016 11:35 AM
Trading my Smoked Valenti tails bnib for the red and white bar Valenti Xplicit Canada Classifieds 3 03-24-2016 02:39 PM
SOLD -Valenti Tails and Valenti 3rd light (Smoked) / Wheelhaus' headliner brake light AtlasMick Exterior Parts (Aero, Lighting, Etc.) 8 03-07-2015 06:51 PM
WTB: Smoked Valenti Tails. Smoked Valenti Reverse. Spec-D Headlights. Kephrii Want-To-Buy Requests 0 02-18-2015 01:42 PM
