Old 11-18-2018, 03:27 PM   #1
Levamentum
Drives: 2014 BRZ Limited. WRB
Exhaust problems
Hello all, this is my first post here but I needed to find an answer to a problem that I ran into installing some exhaust parts.
To begin I am new to modding vehicles and this is my first foray into mods.
I decided to start with exhaust on my 2014 BRZ. I purchased Borla header, JDL front pipe/over pipe combo, and a Greddy catback exhaust system.
Everything was going fine and honestly everything *is* fine except the connection between the front pipe and the Greddy midpipe. The donut gasket on the front pipe does not fit appropriately into the Greddy pipe and is the only problem I am having. If not for that simple little issue, I would be done with the work. Do I need to cut the donut off?
The Greddy catback came with 3 gaskets and it has 3 connections that those gaskets can be used on. It even suggests using a donut on the midpipe but the donut on the JDL pipe does not want to fit. So here is where I am. One connection, one problem, and I need a solution.
Levamentum is offline   Reply With Quote
Old 11-18-2018, 04:02 PM   #2
Strife26
Strife26's Avatar
Drives: 2015 Subaru BRZ Series.blue
Did you tighten them from headers back in order? You can try loosening bolts and then try fitting the problem portion.
You can buy thicker gaskets just for issues like that (idk how big your gap is).
And it's possible they just don't fit up.
I usually just finagle the pieces by loosebing bolts and giving it some oomph before tightening the bolts.
That's all I got, sorry.
Sent from my SM-G950U using Tapatalk
Please only adult answers.
I'm stupid, retarded, a fkn idiot, and I will kill myself after a couple answers, I already know this (thanks to the interwebs and its logic) so feel free to leave those responses out, thanks.
Strife26 is offline   Reply With Quote
Old 11-18-2018, 06:42 PM   #3
Trueweltall
Trueweltall's Avatar
Drives: 2016 Subaru BRZ
The donut gasket isn't meant to fit into the pipe completely, you should have bolts with springs that keep the front pipe donut gasket securely against the midpipe.
Trueweltall is offline   Reply With Quote
Old 11-18-2018, 07:37 PM   #4
humfrz
A picture of where the pieces aren't fitting together right, may help us help you -
humfrz
VVT Problems: 100$ reward for a solution!! Exhaust targets all 0, intakes no response bren5279 Forced Induction 12 03-14-2017 07:34 AM
Florida Keys and a loud exhaust- will I have problems guybo Southeast 2 10-04-2016 07:31 PM
Buddy Club Race Spec Coilover Problems on Problems on Problems mpross Suspension | Chassis | Brakes -- Sponsored by 949 Racing 48 09-04-2016 11:18 PM
Drop in, silicone tube, exhaust, NO tune...problems? BlackyRose Engine, Exhaust, Transmission 19 07-06-2013 12:57 PM
My AP Exhaust Problems! track_warrior Engine, Exhaust, Transmission 118 12-09-2012 11:06 PM
