Old 11-12-2018, 05:31 PM   #1
Kitty
Kitty's Avatar
ABS and traction control light
My FRS recently just started having the ABS and traction control light come on after I hit the brakes. It goes off if I turn on and off and if I dont hit the brakes right away. It also messes with my cruise control and it burns out the fuse to my brake lights.
I know thats alot but has anyone else had to deal with this and how did you fix it?
Thanks
Kitty is offline   Reply With Quote
Old 11-12-2018, 05:33 PM   #2
ggiddix
Drives: scion frs
Did you put led lights in anywhere?
Sent from my SM-G965U using Tapatalk
ggiddix is offline   Reply With Quote
Old 11-12-2018, 05:36 PM   #3
Kitty
Kitty's Avatar
Yeah my headlights but they were running fine for a year before this happen.
Old 11-12-2018, 05:37 PM   #4
ggiddix
Drives: scion frs
Oh ok, I put the wrong leds in my license plate light and the same thing happened
Old 11-12-2018, 06:22 PM   #5
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I had to install resistors inline with my LED lights. I had the Stop fuse blow... LEDs are very efficiant, the car sees them as a direct short compared to an incandecent bulb. why the resistor is needed.
I LIKE TIRES!
Spuds (11-12-2018)
Old 11-12-2018, 07:45 PM   #6
Kitty
Kitty's Avatar
I retract my last statement after a long outline of how long ago and how long I had her in storage. After two months of getting her out of storage she started having that problem.
Old 11-12-2018, 07:48 PM   #7
Kitty
Kitty's Avatar
what type of resistors did you use? And do you have pictures?
Old 11-12-2018, 08:45 PM   #8
fx1mark
fx1mark's Avatar
Drives: red 2014 FR-S
just do a google search for led resistors.
fx1mark is offline   Reply With Quote
The Following User Says Thank You to fx1mark For This Useful Post:
Leonardo (11-12-2018)
Old 11-13-2018, 02:20 AM   #9
Brayden_23
Drives: Asphalt 2015 FRS
Google this topic, this is not uncommon. Typically due to damaged ABS sensors, or more potentially a bad brake light switch by the brake pedal
Brayden_23 is offline   Reply With Quote
Old 11-13-2018, 08:05 AM   #10
Grady
Grady's Avatar
A couple things that are probably right on your car but worded wrong above. LED are seen as an open circuit due to the low current draw. The best option is to replace the flasher with one designed for LED’s. If not the resistors need to be installed in parallel to the LED’s. If you had the stop fuse blow due to an LED installation there is an issue with the LED or circuit.
Old 11-13-2018, 09:25 AM   #11
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I work with LEDs. I made my own lighting. I used a adj resistor, tested its ohm load, and replaced it with a standard resistor. So, its custom. And, my resistors are in series.
I LIKE TIRES!
Old 11-13-2018, 10:48 AM   #12
Grady
Grady's Avatar
Can you post you wire diagram and component specs? That would narrow down if the issue is somewhere else than you lights.
Old 11-13-2018, 10:59 AM   #13
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I don't have an issue. OP, does. I was just saying that if our cars have the wrong resistance for the lighting; it can blow fuses. And that the ohm load of an incandescent bulb is much higher than an efficient LED. (or group of LEDs in series)
You can direct hook 4 three volt LEDs in series to a 12v circuit. But, the voltage to our cars jumps to 14.5v when the car is started. Thus the need for a resistor, so as not to overdrive the (small) LEDs I am using. I 'm using 18 5mm LEDs in a series / parallel configuration with a resistor in one location. I have different configurations in different locations.
I LIKE TIRES!
Old 11-13-2018, 11:37 AM   #14
Grady
Grady's Avatar
My bad got my OP crossed. 99% of the time when people talk about installing LED they are buying lamp replacements with the voltage regulator build into the base. Not like you that purchased raw LED’s and yes needing to control the voltage to them with a dropping resistor or regulator.
The Following User Says Thank You to Grady For This Useful Post:
Leonardo (11-13-2018)
Traction control and ABS light on after LCA install Geese1 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 10-07-2024 12:03 AM
Check Engine light and Traction Control Light JeRM Issues | Warranty | Recalls / TSB 25 06-02-2023 09:00 PM
Traction control warning light Armin93 Scion FR-S / Toyota 86 GT86 General Forum 5 03-18-2017 03:50 PM
No traction control/ABS light on Hollwood_lives CANADA 6 01-13-2016 09:11 PM
Engine Check light, Traction Control light, cruise control light all on suddenly wqc3241 Software Tuning 2 01-10-2016 07:37 AM
