Old 11-12-2018, 12:55 PM   #1
brz fred
Drives: 2015 Brz
Coilover thrust / radial bearing
So i have a set of apexi n1 coilovers, I've developed the twang/thunk sound while turning the wheel from a stop to very slow speeds, 1-5mph. From what i found on google, entry level coilovers w/ pillowball mounts are not designed for street use and causes the spring to bind. Some posts recommend adding a thrust bearing for a fix. So before i order a set of these thrust bearing kits off summit , my question is are these okay? the inner diameter of the apexi spring is 62mm(2.44") and these bearings are 63.5mm (2.5"), should i keep seaching for a thrust beaing w/ a ID of 62mm? are there better options? I see fortune auto sells sealed radial bearings but they use a 60 ID spring so I guess I'm SOL.
2015 BRZ
Perrin Catback | Gruppe-s UEL | Gram Lights 57xtreme | STI Brembos | RCE Super Street-1 Coilovers | Tom's | ECUtek
brz fred is offline   Reply With Quote
Old 11-13-2018, 02:57 PM   #2
brz fred
Drives: 2015 Brz
After the post I realized I could just ask apexi usa, they got back to me in 24 hours and they actually sell a thrust bearing for the N1 ExV dampers. Here https://apexi-usa.com/suspension-com...er-spring-seat
2015 BRZ
The Following User Says Thank You to brz fred For This Useful Post:
wparsons (11-13-2018)
FREE Radial Bearing and Locking Perch Upgrade! THMotorsports.com Brakes, Suspension, Chassis 1 10-26-2017 11:52 AM
Thrust/pillowball mount bearing clunk while steering VacantSky Issues | Warranty | Recalls / TSB 14 06-04-2015 12:43 PM
Thrust Bearing Going Out >(559)< FR-s Issues | Warranty | Recalls / TSB 22 06-19-2013 08:23 PM
Fortune Auto New Roller/Radial Bearing JPxM0Dz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 03-29-2013 11:31 PM
