Old 11-11-2018, 03:30 PM   #1
Var
Drives: 2017 Subaru BRZ PP
Can't get air out of brake system
My friend has a 2016 FRS. He accidentally got air in the system by letting the fluid in the reservoir run low during a flush.
He bled the car the old fashioned way a few times. We also tried using a vacuum evacuator which is the method I've used multiple times on my BRZ PP and Miata, and I always get a firm pedal that way. Didn't work for his car.
The car still has an initial soft pedal, for maybe 2 inches off the top. The brakes still work ok. The second pump is really firm and how it should be all the time.
Do we need to cycle the abs pump to fix this? Any other suggestions?
Var is offline   Reply With Quote
Old 11-11-2018, 03:40 PM   #2
Ultramaroon
not playing cards
Ultramaroon's Avatar
No. Don't mess with the ABS unit. Unless it is triggered while air is actually in key places, its internals will not be exposed.
Go with a bench bleed of the master cylinder.
Old 11-12-2018, 12:03 PM   #3
brz fred
Drives: 2015 Brz
before you take off the master, try pumping it up and cracking open the lines on master cylinder one at a time, I normally don't have to bench bleed it. When I have customers come in w/ broken lines and dry reservoir, I normally bleed the master in the car, do the calipers and then I'll active the ABS a few times if the pedal doesn't feel right. but thats my 2 cents
2015 BRZ
Perrin Catback | Gruppe-s UEL | Gram Lights 57xtreme | STI Brembos | RCE Super Street-1 Coilovers | Tom's | ECUtek
brz fred is offline   Reply With Quote
The Following 2 Users Say Thank You to brz fred For This Useful Post:
Ultramaroon (11-12-2018), Var (11-12-2018)
Old 11-12-2018, 02:47 PM   #4
Var
How to you activate the abs? By driving and flooring the brakes or with a scan tool?
Old 11-12-2018, 03:21 PM   #5
brz fred
Drives: 2015 Brz
you'll need software, try the bleeding the master and doing all the calipers again. if it's still not there I'd just bite the bullet and pay a respectable shop their hour labor or w/e and have them plug into and do it.
2015 BRZ
The Following User Says Thank You to brz fred For This Useful Post:
Var (11-12-2018)
For Sale : Beatrush Direct Brake System Cheddaa AFRICA 0 02-09-2017 08:28 AM
Brake system question zjasontz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 06-04-2016 12:12 AM
Hawk Performance Brake System D.Scrye Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 09-08-2013 11:16 AM
BRZ Brake system specs antlers Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 04-09-2013 06:00 PM
Brake override system in the FT-86? mrKiKaZ Scion FR-S / Toyota 86 GT86 General Forum 10 02-22-2010 11:33 AM
