Old 11-09-2018, 09:51 AM   #1
WVAsphalt
Drives: 2016 Asphalt FR-S
Main Body ECU (BCM) replacement
Hey, I need to replace the main body ECU on my 16 FR-S. It's not sending ground to the drl relay because I accidentally sent power through that control circuit. Anyway, the dealership wants 2 hours labor to install, and they refuse to install a used one. Has anyone had to do this yet? I'm hoping to not need techstream to initialize it. The manual says if replacing with an OTHER THAN NEW ECU, that you only have to jumper two pins in the OBD port, but it doesn't specify for the Main Body ECU. Any experience would be great, especially from a tech.
Sent from my SM-N950U using Tapatalk
WVAsphalt is offline   Reply With Quote
Issue with Main Body ECM Kordless Electronics | Audio | NAV | Infotainment 8 03-07-2018 10:09 AM
TRD Body Kit Replacement Hardware Grishbok Cosmetic Modification (Interior/Exterior/Lighting) 5 04-03-2017 12:23 PM
Any Scion / Toyota service techs here? Main Body ECU replacment question. boomslang Scion FR-S / Toyota 86 GT86 General Forum 4 08-30-2014 01:56 AM
Summit Main 9/14-9/15 fredk Mid-Atlantic 2 09-02-2013 11:59 AM
WTB Main Body ECU Acree Interior Parts (Incl. Lighting) 2 03-05-2013 05:31 PM
