| DIY (Do-It-Yourself) Guides For all DIYs. |
Drives: White 13 FRS
Custom exhaust delete cover
Going single exit, I knew I would have an empty hole on the opposite side. I know there are covers available, but I wanted to try a custom approach recommended by someone on a local FB group.
The materiel I used is a plastic called kydex, purchased from amazon for around $12: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 In case you haven't seen an exhaustless FRS bumper... ![]() Kind of revealing imo, unless you're trying to show off some flashy suspension components. I started with a cardboard/blue tape (lol)/aluminum food tray stencil that I could easily bend, cut and add to to get the general shape correct. ![]() ![]() Then, I traced the stencil on the backside of my work piece and cut it out with an acrylic knife. ![]() ![]() ![]() ![]() ![]() After sanding the rough edges off from cutting, I started heating the materiel with a blow dryer to bend it. Being 0.06" thick, a heat gun or the oven was overkill for heating. ![]() ![]() ![]() ![]() Test fitting... ![]() ![]() ![]() I had to rivet on some extensions on the sides because my original mount pieces couldn't bend the same way as my cardboard stencil... ![]() After fitting it up and drilling it in with self tapping screws, I took it off again to vinyl wrap the face that you see. The raw kydex didn't match in color to the bumper, so I used some left over satin black vinyl from my lip kit. ![]() ![]() ![]() ![]() The finished product: ![]() ![]() I used liquid nails between the extensions, the cover and the rivets to minimize movement. More pictures from different angles... ![]() ![]() ![]() Overall happy with the finished product for the price. There is a slight kink on the bottom and a dimple in the top, but you can't really see it unless you're looking at it from a crouched height or under the car.
Drives: '08 MX5 6MT & '15 BRZ Premium 6MT
Nice BRZ bro.
Drives: FRS 2013
Not bad, the $50 piece from ft86factory definitely isn't worth it
#5 | |
| FS: 2017+ 86 Passenger Side Exhaust Delete Cover | edwardl | Exterior Parts (Aero, Lighting, Etc.) | 8 | 07-31-2019 12:03 PM |
| FRS/BRZ Custom 3" Exhaust and matching Custom Diffuser Combo | Guff | Engine, Exhaust, Bolt-Ons | 0 | 08-07-2018 10:38 PM |
| berk muffler delete/ Ft86speedfactory exhaust hole cover package deal | Ripp91 | Engine, Exhaust, Bolt-Ons | 0 | 06-09-2015 03:55 PM |
| Custom USB Cover Switch | Chad86 | Scion FR-S / Toyota 86 GT86 General Forum | 14 | 01-12-2015 06:08 PM |
| Anyone interested in custom steering wheel cover? | RedlineGoods | Cosmetic Modification (Interior/Exterior/Lighting) | 40 | 07-31-2014 05:24 PM |
