Old 10-31-2018, 07:13 AM   #1
frs_mikey
Drives: White 13 FRS
frs_mikey (Street/Track Build)
Welcome to my build thread! My goal is to build a cool looking FRS for the streets that is track capable.
Day One 1/26/2015 - Picking her up
Current 9/7/2018
Engine & Exhaust:
- Perrin CAI
- Zeta Performance silicone inlet tube
- Optima redtop 35 battery
- Stock exhaust (daily)
- Nameless Performance muffled trackpipe (track)
Suspension & Brakes:
- TRD lowering springs
- TRD brake pads
- Porsche GT3 brake ducts
Wheels & Tires:
- Rays Engineering Gramlights 57DR 17x9 +38
- Hancook Ventus V12 Evo 2 245/40/17
- Muteki SR48 lug nuts
Current Fluids:
Brake & Clutch: Pentosin DOT 4
Engine: Whatever 0w-20 Toyota oil (1/21/19 - )
Transmission & Diff: Motul gear 300 75w90
Alignment:
(10/1/2016)| Camber: FL= -0.17 FR= -0.10 R= -1.77 | Toe: FL= 0.01 FR= 0.02 R= 0.05
Interior:
- Broadway 300mm convex mirror
- JBL speakers
- Alpine amp
- JL 10 inch subwoofer + amp (+10 lbs in the rear for grip lol)
- Pioneer 4200NEX headunit
- Raceseng Prolix shift knob
- Raceseng Contour shift knob
- Raceseng R lock
- Scosche suction cup magnetic phone mount
- 86 center console logo plaque
Exterior:
- Bayson R TRD style sideskirts
- Bayson R Nur spec style rear spats
- DDM Tuning HID headlight upgrade (6000k)
- GCS smoked sidemarkers
- Ikon Motorsports RS 1.0 style front lip
- Ikon Motorsports TRD style side spoiler
- Nokya hyper yellow halogen DRL bulbs (3000k)
- Sirus LED switchbacks
- Valenti/Helix sequential tail lights
- Valenti 4th brake light/reverse light
Misc:
- Custom InitialD JDM vanity plate (for trackdays (need to make a USDM body to JDM plate mount))
- GoPro Hero 7 Black
- GoPro Hero 5 Session
- Zamp RZ-58 SA 2015 helmet
Inventory:
- Grimspeed strutbar
- Nur spec style rear spats
- SPC camber bolts
- TRD style side spoilers
Previous parts:
- Nameless Performance 2.5in axleback, 5in cans (dual exit) (preownership - 10/27/2018) sold
Inspitations:
Toyota Griffon
Revolution 86
Trackdays:
3/10/2018 - First event w/ OnGrid (Thunderhill West)
2/23/2019 - Second event w/ SpeedSF & 86DRIVE challenge event #1 (Thunderhill East)
Social:
https://www.instagram.com/frs_mikey/
https://www.youtube.com/channel/UCFv...qRTmCMp1cPns3w
frs_mikey is offline   Reply With Quote
Old 10-31-2018, 08:08 AM   #2
frs_mikey
10/27/2018 | Nameless muffled track pipe
Updated exhaust! Nameless dual axleback was on before I got it. It sounded great, I just wanted something different and single exit. I ended up going with the Nameless muffled track pipe because it's such a high quality product at a low cost. Happy with my switch, sound clips may be posted soon.
Weight stuff: (pulled from http://www.ft86club.com/forums/showthread.php?t=42555 and Nameless Performance's website)
Stock: 26.1 lbs
Nameless dual: 17 lbs
Nameless single: 6lbs
Old 10-31-2018, 08:33 AM   #3
Tomm
Identifying as a Member
Tomm's Avatar
Drives: 2013 FRS LS1
Very clean! Whats next?
Tomm is offline   Reply With Quote
Old 10-31-2018, 11:13 AM   #4
JeremyR
JeremyR's Avatar
Drives: 2015 BRZ Limited
Looks good man very clean!
REALMS BRZ Build Thread
HKS|Parts Shop MAX|Battle Version|ADVAN|Beatrush
JeremyR is offline   Reply With Quote
Old 10-31-2018, 02:00 PM   #5
frs_mikey
Thanks! Nothing big at the moment, I want to try making an exhaust delete cover for the passenger side.
Depending on what’s around me, I think my next move will be some driver mod
Old 10-31-2018, 02:02 PM   #6
frs_mikey
Thaank youu!
Old 11-04-2018, 01:40 AM   #7
frs_mikey
11/3/2018 | Custom exhaust delete cover
Going single exit, I knew I would have an empty hole on the opposite side. I know there are covers available, but I wanted to try a custom approach recommended by someone on a local FB group.
The materiel I used is a plastic called kydex, purchased from amazon for around $12: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
In case you haven't seen an exhaustless FRS bumper...
Kind of revealing imo, unless you're trying to show off some flashy suspension components.
I started with a cardboard/blue tape (lol)/aluminum food tray stencil that I could easily bend, cut and add to to get the general shape correct.
Then, I traced the stencil on the backside of my work piece and cut it out with an acrylic knife.
After sanding the rough edges off from cutting, I started heating the materiel with a blow dryer to bend it. Being 0.06" thick, a heat gun or the oven was overkill for heating.
Test fitting...
I had to rivet on some extensions on the sides because my original mount pieces couldn't bend the same way as my cardboard stencil...
After fitting it up and drilling it in with self tapping screws, I took it off again to vinyl wrap the face that you see. The raw kydex didn't match in color to the bumper, so I used some left over satin black vinyl from my lip kit.
The finished product:
I used liquid nails between the extensions, the cover and the rivets to minimize movement.
More pictures from different angles...
Overall happy with the finished product for the price. There is a slight kink on the bottom and a dimple in the top, but you can't really see it unless you're looking at it from a crouched height or under the car.
Old 11-04-2018, 10:20 PM   #8
DuMa
DuMa's Avatar
Drives: LR BRZ Limited
wall of wheels is kinda cool. what BMW do you have?
DuMa is offline   Reply With Quote
Old 11-05-2018, 04:12 AM   #9
frs_mikey
M3, father owned lol. All the garage stuff is my dad's doing as well
Old 01-12-2019, 09:18 AM   #10
frs_mikey
Just some updates
11/12/18
Annual oil change! Nothing special, just more Mobil 1 5w-30 and an oem filter.
12/14/18
I’ve been wanting to try Raceseng’s Contour shift knob for a while now and it was in the Christmas clearance sale! I’m not sure how I like it compared to my Prolix I’ve had since it’s release. The shortened height makes it feel more direct, but feels like it has to travel further to go into gear... Although, it looks really nice with the shift gate engraving.
1/5/19
Recall time. Scheduled to go in next week, fingers crossed.
1/10/19
Back to stock... exhaust law revisions in CA made me do this. Will be holding onto my track pipe for, well... the track... or until everything is reversed? (Doubtful). Also swapping my intake to make the job easier for the poor Toyota tech that has to go into my Subaru engine.
(I apologize for the portrait pictures, all of this was taken with my phone through instagram stories)
Old 01-15-2019, 01:08 AM   #11
frs_mikey
1/14/2019 | Valve spring recall day
1/14/19
Dropped my FRS off at Toyota this morning for the valve spring recall. The person at the service desk said the work should take 3-5 business days if I remember correctly. Fingers crossed that everything goes smooth.
Old 01-22-2019, 06:23 PM   #12
frs_mikey
Update on my valve spring recall. Picked up the car last night, making the service time 1 week and some hours for me. Car runs smooth, while the engine was out I took the opportunity to get my throw out bearing and spark plugs replaced. Happy with my recall experience so far, will update if anything comes up in the future.
Old 01-25-2019, 12:23 PM   #13
gkubed
gkubed's Avatar
Drives: 15 ZN6, 97 NA8, 87 AE82, 78 MX32
Originally Posted by frs_mikey View Post
1/22/19
Good call on the TOB/spark plug replacement!
gkubed is offline   Reply With Quote
Old 01-31-2019, 06:19 AM   #14
frs_mikey
1/30/2019 | JDM muffler tips for stock exhaust
Earlier this week, I purchased some "stock 2015" exhaust tips I found on a FB sale ad. They were slightly damaged when I saw them in person, but was too good a deal to pass up! (The damage isn't noticeable either when installed, so I lucked out there.)
Installed them today in my school parking structure (lol). However when I showed my friend with a 2015 FRS, he told me that I actually had JDM tips. I was pleasantly surprised since I actually really wanted these, but wasn't looking to pay full price for a brand new set.
'17 Toyota 86 Euro spec model - NA build/Street/Track Philliplo Member's Car Journals 20 11-21-2018 11:15 AM
Racer 713's DD Street/Track build racer713 Member's Car Journals 6 08-11-2018 10:04 AM
2016 Toyota 86 GTS Street/Track Build arthur93 Member's Car Journals 77 02-22-2018 07:07 PM
Megan Racing Coilovers - Street / Track / EZ STREET - Starting at $699 Shipped GuerillaRacing Brakes, Suspension, Chassis 149 05-12-2015 05:53 PM
