Old 10-29-2018, 08:54 AM   #1
Anderzz
Anderzz's Avatar
Drives: 2013 Subaru BRZ Premium
Squeal when leaving a stop
Interested on people's thoughts on an issue I'm having. Clutch was swapped less than 3k miles ago to a Southbend Stage 3 Enduro with a 2017 OE TOB, Motul fluid.
When leaving stops I currently get a weird squeel at the very top of the clutch engagement before moving. Sound is brief, variable, but is considerably different from a TOB failure sound.
Any idea of potential culprits? Originally thought it may be a wheel bearing going as it sounds like something spinning is causing it but it doesn't correlate to wheel spin.
Any insight is appreciated
Sent from my XT1650 using Tapatalk
Anderzz is offline   Reply With Quote
Old 10-29-2018, 02:19 PM   #2
StraightOuttaCanadaEh
Wes
I may be wrong here, but I think it's the flywheel that starts squealing. Did you take a peek when swapping out the clutch? The same squeal happened to me in my previous car and when I went to change the clutch, the flywheel was pretty bad. Sometimes you can get away with resurfacing but I had to get a new one. Squeal was gone after that.
Instagram: @gt86ws
The Following User Says Thank You to StraightOuttaCanadaEh For This Useful Post:
Anderzz (10-29-2018)
Old 10-29-2018, 02:25 PM   #3
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
Is it only when you start from a stop? Or anytime you release the clutch? The clutch fork could be squeaking where the slave cylinder hits it, or on the pivot ball. Try greasing those areas if you haven't.
BigTuna is offline   Reply With Quote
The Following User Says Thank You to BigTuna For This Useful Post:
Old 10-29-2018, 02:45 PM   #4
Anderzz
Anderzz's Avatar
When the clutch was swapped out we dropped in a brand new exedy flywheel as well so I would be surprised if that was the issue.
Old 10-29-2018, 02:46 PM   #5
Anderzz
Anderzz's Avatar
Only from a stop.
I have to release the clutch around 95% and then right as its catching there's 1-3 seconds of variable squeal.
squeal of a clutch LowAndSlowBecauseNoTurbo Issues | Warranty | Recalls / TSB 12 03-07-2017 01:21 PM
Brake Squeal bg15 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 08-27-2016 10:51 AM
Brake Squeal Maritime Storm Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 03-01-2015 10:59 AM
Blower fan squeal 2point0 Issues | Warranty | Recalls / TSB 4 04-01-2014 07:40 PM
No Squeal Track Pad? gbgracer Tracking / Autocross / HPDE / Drifting 15 03-27-2013 08:21 PM
