Corner Junkie
Drives: 13 BRZ, 11 STI, 99 RS
Tap Tap noise from the trunk: Found.
So, went on a LONG road trip the other day and along the way I noticed that on some bumps there would be a single "Tap" noise from the trunk area. Sometimes from hitting a bump with only one side of the car, sometimes with both, and rarely when making a turn.
It annoyed me because it was a clear and audible tap that sounded like something loose hitting the trunklid or fender, but when I removed everything the sound continued. I found it last night. The Emergency release pull for people inside the trunk was making the noise. Turns out it will snap into a bracket where it's mounted to keep the tapping noise from happening. I guess when a friend was asking about it he pulled it from the stowed position and left it loose. So if you get a singular "Tap" from the rear when hitting a bump, check to see if that glow in the dark handle is loose. |
| The Following 9 Users Say Thank You to Draco-REX For This Useful Post: | ahausheer (07-29-2012), blu_ (07-29-2012), Bonburner (02-28-2013), civicdrivr (07-29-2012), Marrk (07-29-2012), SPEEDGOD (02-13-2013), usdmnotjdm (09-05-2013), VenaSera (02-13-2013), WolfpackS2k (09-09-2013) |
Waited 5 years for this
Drives: '18 MX-5 Club
I made sure it's put in place but it was still making noise. I even taped it to make sure it won't move or touch anything, but it's still making noise. I wonder whats making noise in mine.
FReSh Mobile
Yeah that was one issue people were having, but the more widespread one seems to be the third brake light hitting the back window (theory) or something loose in that area.
Re-member
Drives: Toyota camry
Sometimes these little threads actually make a big difference, thanks for posting.
Nothing decays like progress, and nothing preserves like neglect.
| The Following User Says Thank You to ahausheer For This Useful Post: | ftc~brz (02-28-2013) |
Drives: 1995 Ford Probe
hmmm i have heard this as well.. usually right after i pull out of my parking spot after i start the car.. i thought it was a sport water bottle in my trunk.. will have to clean out the trunk and compare
low and behold that green handle wasnt snapped in place. snapped it back in but im too tired to go test driving now so tomorrow i will be looking out to see if i hear that noise anymore. thanks!
Drives: 2013 Scion FR-S Firestorm Red MT
Sometimes when I skim through the forums, I mistakingly read "Fap Fap noise from the trunk."
| The Following 3 Users Say Thank You to eriktherod For This Useful Post: |
#11 |
Corner Junkie
Well, seems my noise is back. Guess the handle wasn't it. But I can still see it making a noise as it bounces around. So I'll leave this thread as-is.
I did notice that it seemed like the tapping noise wasn't noticeable when it rains. It was raining the night I fixed the handle. Time to start hunting. |
#12 | |
#13 |
Cones are bad
Drives: 2013 BRZ Premium
The 2 styrofoam pieces that hold your tow hook, jack, and other tire change pieces are not completely secured. The will bounce and make noise on speed bumps and some other bumps
| The Following User Says Thank You to RazBRZ For This Useful Post: | SPEEDGOD (02-13-2013) |
#14 | |
I don't lie.
Drives: AE86 Successor
2. I snapped the emergency handle back in it's holder, I think this should do it: <------Didn't work, I taped it too 3. Put ear plugs in the rear deck creases it worked for one ride and started again, I think I need to stick something it it... (DOESN"T WORK) 4. I tried opening and shutting the back seats back and the noise is gone, I think the red indicator that it's not locked in place is not a good indicator because even when you think you snapped it in place, sometimes it's still loose. AWESOME no more rattle! Last edited by SPEEDGOD; 02-27-2013 at 05:00 PM. |
| Stock Nav swap from BRZ to FR-S & Five Axis trunk spoiler install on BRZ trunk? | 07stealth350z | DIY (Do-It-Yourself) Guides | 8 | 08-27-2020 03:27 PM |
| Fan noise? | djliquidsteele | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 07-30-2012 05:22 PM |
| LSD noise | wheeladdict | CANADA | 2 | 07-09-2012 03:21 PM |
| rattling noise in the trunk | ayetothejay | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 06-26-2012 11:19 PM |
| HID noise | Carlsbad | BRZ First-Gen (2012+) — General Topics | 6 | 06-20-2012 12:39 AM |
