Old 10-24-2018, 11:58 PM   #1
Bread1
Drives: Scion Frs
Wheel poke, will lowering it with spring tuck them?
I have 17x9 wheels with a 35 offset and want to lower the car but im not sure if i lower it if it will work correctly since my tires poke i think it will hit the fender.
Bread1 is offline   Reply With Quote
Old 10-25-2018, 08:04 AM   #2
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
You'll be fine.
http://www.ft86club.com/forums/showthread.php?t=15160
BigTuna is offline   Reply With Quote
Old 10-25-2018, 02:23 PM   #3
Bread1
Drives: Scion Frs
Originally Posted by BigTuna View Post
Ok thanks!
Old 10-25-2018, 02:27 PM   #4
Leonardo
Country Boy 4 Life
Leonardo's Avatar
You will get -2ish camber in the rear from lowering. But not the front. So, I'd suggest getting a set of camber bolts for the front. This will help them "tuck".
I LIKE TIRES!
Old 10-26-2018, 06:01 PM   #5
tyler_win_photo
tyler_win_photo's Avatar
Depends on drop and alignment.
tyler_win_photo is offline   Reply With Quote
Uneven wheel poke after alignment Baldoak Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 04-13-2018 03:51 PM
Lowering spring and wheel fitment question. coupeae86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 08-29-2016 04:34 PM
How to fix wheel poke tskaohu Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 06-10-2016 02:58 PM
Pic Request: front wheel poke of 17x9 or 18x9 +35 on Prokit, TRD, RCE, or similar btoast Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 02-26-2015 02:38 AM
Adjusting camber to tuck in the wheel..? Yamajee Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 29 11-12-2013 03:58 PM
