Old 10-21-2018, 12:47 PM   #1
Traffic
Drives: 2016 BRZ Limited Automatic
205/65/16 On stock hight?
Hi guys has anyone fitted 205/65/16 tires on the twins without any rubbing?
I have ran 205/60/16 on 50mm offset 6.5 inch steelies for two winters (Generial Altimax Winter Tires) with no rubbing or issues. Now I'm going to be purchasing the Blizzacks and want to try the taller tire size for more ground clearance.
@churchx told me he recalled a post that stated
Originally Posted by churchx View Post
1) i recall post on stock wheels, that "225/55/17 rubs, 225/50/17 fine".
So I used @dominicpadawan wheel fitment calculator https://www.ft86motorsports.com/wheelitfit/ use those sizes as a baseline to see if I can get an idea if it will rub or not. Still not sure if it will.
It says that the 205/60/16 tires are in the red but I know they fit with no issues, so I,m not sure I can go by it.
Any help would be appreciated.
Thanks
Traffic is offline   Reply With Quote
Old 10-21-2018, 01:43 PM   #2
churchx
churchx's Avatar
Drives: 2014 GT86
That post was here, if matters. Pitty w/o details, rubbing where & how exactly. After all, depending on wheel & tire width it may differ if it's on wheel arch, or on endlinks, or on strut, or when suspension bottoms out (and i can only assume/guess, that on stock suspension & alignment) .. only thing mentioned, that 225/50/R17 didn't rub turned lock to lock.
Be aware, that in this case it's on stock 17" wheels/stock offset and with wider tire of 225, instead of 205 for you.
Old 10-21-2018, 03:08 PM   #3
mrg666
pessimistic skeptic
mrg666's Avatar
Thanks
215/45-R17 has 24.6" height for reference
205/60-R16 is 25.7"
205/65-R16 is 26.5"
I think more than one full inch difference is a little too much.
If you go to 205/55-R16 it is an acceptable 24.9" height. Go with 205/55-R16.
Old 10-21-2018, 03:25 PM   #4
churchx
churchx's Avatar
Drives: 2014 GT86
OP's goal is not closest to stock. But largest that won't rub.
Old 10-21-2018, 04:29 PM   #5
Traffic
Good point that is why I think I can get away with it because it is a thinner tire, that may give me the wiggle room.
Old 10-21-2018, 04:31 PM   #6
Traffic
205/60-R16 is 25.7"
205/65-R16 is 26.5"
I'm looking for the tallest without rubbing. The clearance is worth it, and the trade off in regular driving is acceptable for me.
FS: Stock brake lines, stock clutch line, stock motor mounts Agent_D Brakes, Suspension, Chassis 4 08-22-2017 12:24 PM
**Prodrive: GT1 ALL In Stock!!** Enkei: RPF1, T6S, Konjin, TSP6, Raijin ALL in STOCK OAKOS Automotive Wheels and Tires 290 03-01-2016 10:32 AM
FS: Openflash, Weathertechs,Mtech Trasmission Springs, Stock Exhaust, Stock intake Brahsbrah Canada Classifieds 11 11-09-2014 11:03 AM
WTB: Stock MAP Sensor, Stock Frontpipe, Stock Midpipe. Sterz Engine, Exhaust, Bolt-Ons 4 07-02-2014 09:22 PM
