Drives: Subaru BRZ
Hi everyone,
As a final project of my masters degree (automotive engineering) i am going to some dyno tests with my BRZ. I am gonna test these on dyno: - RON95 with stock tune - RON95 with stg1 tune - RON95 + 10% Ethanol (E10) with stock tune - RON95 + 10% Ethanol (E10) with stg1 tune - RON95 + 20% Ethanol (E20) with stg1 tune - RON95 + 85% Ethanol (E85) with E85 tune I need help about 2 things. 1. How can I drain fuel out of tank easily? Because I am gonna need to drain fuel in the tank and put new mixture. Or any suggestions for this? 2. We all know after flashing a tune, first 50 miles is just learning for ECU. What is the procedure of dyno'ing a new tune? How can I flash and dyno? Thanks in front |
#2 | |
Drives: UK GT86
If you're flashing a tune, make sure that you have a well dialed in MAF/injector setup for the changes in ethanol and set the IAM to 1 and there is no learning required. Just flash and go. With the stock tune, just change the IAM to 1 or if the 95 RON and the IAM is regularly below 1 you can reduce the advance table by the required amount and set the IAM to 1.
.: Stealth 86 :.
#3 | |
Drives: brz
you dont need to drain it start with almost empty tank add 10% ethanol then add full tank of e85 there is some excel spread sheet online that does the math on how much ethanol you need to add to get your desired percentage, or you could pull one of the fuel line i think the fastest way is to pull the feed line you can do return too i think it would be slower maybe idk and turn ignition on to turn the fuel pump on or even better run 1 gallon fuel tank in the engine bay this way you only need to drain one gallon each run if you want to redo your project if you got wrong data, i mean you shouldnt really use canned tune for research i think you should do your own tune and see how much change in air fuel ratio and fuel demand and how much direct injector angle and cam timing and ignition timing changes i feel this would make your study more about the engine than the tune |
| Shiv dyno day 2 in lewisville, OFT users custom dyno tunes | malubawla | Southwest | 14 | 11-21-2015 01:53 PM |
| Infamous Performance is now offering dyno tunes by Delicious Tuning!!! | Infamous Performance | Announcements, Contests, Giveaways | 115 | 02-28-2014 12:38 PM |
| Infamous Performance is now offering dyno tunes by Delicious Tuning!!! | Infamous Performance | Forced Induction | 107 | 02-13-2014 11:36 AM |
| Dyno Compilation - dyno testing results and recommendations | Illusive | Engine, Exhaust, Transmission | 82 | 02-08-2013 07:00 PM |
| Mach V's Dyno Testing | tjoy | Engine, Exhaust, Transmission | 20 | 08-06-2012 10:52 PM |
