Old 10-13-2018, 09:32 AM   #1
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Diff Backlash
I have been trying to chase down this occasional clunk I have in the rear of my car. Jacked it up and holy jeezus does this thing have some diff backlash Has anyone else noticed this? Seems like I can get more then a quarter turn out of the drive line before the axle moves. Oil looks fine but starting to wonder if my issue is from the diff.
Old 10-13-2018, 12:06 PM   #2
ArCha
Drives: 2013 Subaru BRZ SWP
I have the same problem. Cracked open the diff, replaced the bearings and reset the backlash to spec. The closest thing I've found is that the subframe bushings transmit the clunk noise into the cabin.
ArCha is offline   Reply With Quote
Old 10-13-2018, 02:31 PM   #3
Ultramaroon
not playing cards
Ultramaroon's Avatar
I've wondered about this but I figure as long as it runs dead silent, I won't worry.
What were your before/after numbers? Did you find anything to be sloppy?
Old 10-13-2018, 03:45 PM   #4
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Did going through the diff help resolve some of the noise?
I have inspected most of the bushings in the rear of the car, but that doesn't rule out deflection being the source of the noise.
Old 10-13-2018, 04:19 PM   #5
Ultramaroon
not playing cards
Does it happen when you push the clutch pedal to stop backing up? Driveline lash is pretty obvious.
Old 10-13-2018, 04:26 PM   #6
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Haven't been able to isolate it to a specific instance that causes it. Sometimes it happens on/off throttle, sometimes it does it while swerving, sometimes it does it when I hit a bump. I does not happen under steady state load. I have had the whole back of the car up off the ground and shook parts until I thought it was going to come off the stands and haven't been able to replicate it on the ground. I thought it was a chassis part loose at first but I have kinda figured it is either a fatigued bushing that feels okay when it is static or possibly the diff. I have pulled the CV's and articulated them through their motion but they feel fine. I'm stumped.
Old 10-13-2018, 05:02 PM   #7
Ultramaroon
not playing cards
Sounds opposite of anything diffy.
Old 10-13-2018, 05:08 PM   #8
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Guess I will just drive it until what ever it is gives itself up to the almighty. Figured I would ask the hive mind.
Old 10-13-2018, 05:16 PM   #9
Ultramaroon
not playing cards
Shit. I was just getting interested. Have you tried gradually lifting the sub frame in different places with a floor jack while it was up on blocks?
This may sound dumb but does it feel important?
Old 10-13-2018, 05:28 PM   #10
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I hadn't thought of that and may give it a try. I am starting to wonder if it is my rear sway bar shifting side to side. There is a bit of a gap on one side between the bushing and the little locating ring/collar/thingy.
I have kind of gotten used to it and have to listen for it now. It doesn't sound as bad as it did at first, it is more of a clunk. When it first happened it was a WTF is that. I just asked about the diff being I have never seen one with so much backlash.
Old 10-13-2018, 06:09 PM   #11
Ultramaroon
not playing cards
Right? It's significant. Then if the trans starts to get slutty, it really adds up.
Old 10-13-2018, 07:01 PM   #12
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Your freaking me out man.
Old 10-13-2018, 07:21 PM   #13
Ultramaroon
not playing cards
Does your transmission whine? Unless it whines, you're golden. Even if it whines, meh.
Story time.
I have, like 5000 miles on my original transmission. It started making a teeny bit of noise right after I made a particularly abusive 1-2 shift in the wet on purpose. I drove it carefully for a couple months while I casually looked for a replacement. No one else could hear it whine but I could tell that it changed.
Right out of the gate, my replacement salvage transmission was WAY louder. I'm almost at 50 K now and it hasn't gotten any worse. I'm careful to keep it from slapping around but I'm not worried about it. One of these days, I'll tighten up one or both of them.
Old 10-13-2018, 07:25 PM   #14
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Story time.
No, mine is quiet. No shifting issues, have even made a 5-2nd shift a couple times by mistake on the track and no problems
Which is better? Reaplcing rear diff bushings? or installing rear diff brace? Frs30 Engine, Exhaust, Transmission 22 04-13-2020 10:23 AM
Difference between Whiteline Diff Outrigger Bushings and Diff Cradle kits? mistople Engine, Exhaust, Transmission 10 09-21-2018 06:01 PM
Diff Mount Inserts install - Diff won't lower??? ChRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 07-17-2017 12:07 AM
Diff oil HLHachiRoku Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 7 04-17-2016 06:12 PM
Swap AT Diff with MT Diff sydious Engine, Exhaust, Transmission 2 03-17-2016 02:59 PM
