Drives: 2017 Subaru BRZ Limited
Used vs. New Header
Hi all,
New to the forum and wanted to get some advice from you all -- I'm looking to get a JDL UEL Catless Header for my BRZ. I found someone who is selling it for $500, but it has 20K miles on it. According to the seller though, the header is flawless. Should I go for it or buy a brand new one for $750? Just a little worried since the header has 20K miles on it. Thanks in advance! |
Drives: 2016 Series.HyperBlue BRZ
in my opinion, it's essentially just a pipe. If it isn't crushed, then what's there to worry about? Maybe a little bit of carbon build up, but won't be anything significant after 20k miles. Maybe a few external scrapes? That doesn't impact the function of the piping. I bought my headers used, and no ragerts. You have my vote to go for it, and put that $250 savings towards other mods.
Drives: 2013 FR-S Argento
Yup just a pipe - if it's catted then check the condition of the converter (I bought mine used with a cat), but otherwise as long as it's a good brand (JDL is excellent), welds look good, no damage in general (scrapes/rubs should be fine) then go for it.
Drives: 2013 frs red
If you can easily afford new, buy new. Otherwise a used name brand (not ebay) header will be just fine.
Drives: FR-S,GTI
A new header becomes a used header as soon as you buy it.
| The Following User Says Thank You to WNDSRFR For This Useful Post: | JoeC (10-10-2018) |
Panda Trueno
Drives: No twin now.
Keep in mind you'll want new gaskets. They're cheap but something to consider.
Also might have to replace the hardware on the used parts, again cheap but not included normally. |
Thank you everyone for your input. I think I'll go ahead and buy the used header and put the rest of the money towards other mods
Drives: 2015 BRZ
If you need oem gaskets. Buy them through subaru. Much cheaper than Toyota.
#10 |
Drives: brzzzz
new gaskets are a must.
#11 |
LMGTFY
Drives: 13 FRS, 91 Miata
#12 |
#13 |
Drives: 2016 Scion FR-S
I would almost venture out on a limb and say to get the Grimm speed gaskets or vibrant gaskets I have had pretty good luck with them.
#14 |
I bought the Grimmspeed gaskets for my JDL UEL catless header. Absolutely not leaks. Just make sure you tighten them to the proper torque
| JDL UEL header/Nameless header-back exhaust (Atlanta area) | carbon_raven | Engine, Exhaust, Bolt-Ons | 16 | 05-09-2015 02:26 AM |
| Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? | alanhung85 | CANADA | 6 | 10-21-2014 10:41 PM |
| RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP | NickFRS | Engine, Exhaust, Transmission | 44 | 04-19-2014 05:42 PM |
| Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! | TopGearSolutions | Engine, Exhaust, Bolt-Ons | 82 | 04-14-2014 08:16 PM |
| Gutted cat stock header vs aftermarket catless header NA application | stevo585 | Engine, Exhaust, Transmission | 8 | 04-04-2014 04:12 PM |
