Old 10-10-2018, 08:50 AM   #1
junior-subie
Used vs. New Header
Hi all,
New to the forum and wanted to get some advice from you all -- I'm looking to get a JDL UEL Catless Header for my BRZ. I found someone who is selling it for $500, but it has 20K miles on it. According to the seller though, the header is flawless. Should I go for it or buy a brand new one for $750? Just a little worried since the header has 20K miles on it.
Thanks in advance!
junior-subie is offline   Reply With Quote
Old 10-10-2018, 09:36 AM   #2
ShawnP19
ShawnP19's Avatar
Drives: 2016 Series.HyperBlue BRZ
in my opinion, it's essentially just a pipe. If it isn't crushed, then what's there to worry about? Maybe a little bit of carbon build up, but won't be anything significant after 20k miles. Maybe a few external scrapes? That doesn't impact the function of the piping. I bought my headers used, and no ragerts. You have my vote to go for it, and put that $250 savings towards other mods.
ShawnP19 is offline   Reply With Quote
Old 10-10-2018, 09:48 AM   #3
bfrank1972
Drives: 2013 FR-S Argento
Yup just a pipe - if it's catted then check the condition of the converter (I bought mine used with a cat), but otherwise as long as it's a good brand (JDL is excellent), welds look good, no damage in general (scrapes/rubs should be fine) then go for it.
Old 10-10-2018, 09:50 AM   #4
Lantanafrs2
Drives: 2013 frs red
If you can easily afford new, buy new. Otherwise a used name brand (not ebay) header will be just fine.
Lantanafrs2 is offline   Reply With Quote
Old 10-10-2018, 10:15 AM   #5
WNDSRFR
Drives: FR-S,GTI
A new header becomes a used header as soon as you buy it.
The Following User Says Thank You to WNDSRFR For This Useful Post:
JoeC (10-10-2018)
Old 10-10-2018, 10:15 AM   #6
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
Keep in mind you'll want new gaskets. They're cheap but something to consider.
Also might have to replace the hardware on the used parts, again cheap but not included normally.
Old 10-10-2018, 10:39 AM   #7
junior-subie
Thank you everyone for your input. I think I'll go ahead and buy the used header and put the rest of the money towards other mods
Old 10-10-2018, 11:11 AM   #8
Vital
Drives: 2015 BRZ
Put it towards a tune as you will need it
The Following 2 Users Say Thank You to Vital For This Useful Post:
jflogerzi (10-10-2018), mswbrz (10-10-2018)
Old 10-10-2018, 01:34 PM   #9
Lantanafrs2
If you need oem gaskets. Buy them through subaru. Much cheaper than Toyota.
Old 10-10-2018, 01:46 PM   #10
robotleader
Drives: brzzzz
new gaskets are a must.
robotleader is offline   Reply With Quote
Old 10-10-2018, 04:33 PM   #11
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Highly dependent on location.
Old 10-10-2018, 09:16 PM   #12
Lantanafrs2
Good point. I know Toyota wanted like 75 for all 3 and Subaru was less than half of that, at least where I am. Pays to check.
Old 10-11-2018, 08:08 AM   #13
jjorgen
jjorgen's Avatar
Drives: 2016 Scion FR-S
I would almost venture out on a limb and say to get the Grimm speed gaskets or vibrant gaskets I have had pretty good luck with them.
jjorgen is offline   Reply With Quote
Old 10-11-2018, 10:19 AM   #14
D-rek07
I bought the Grimmspeed gaskets for my JDL UEL catless header. Absolutely not leaks. Just make sure you tighten them to the proper torque
D-rek07 is offline   Reply With Quote
JDL UEL header/Nameless header-back exhaust (Atlanta area) carbon_raven Engine, Exhaust, Bolt-Ons 16 05-09-2015 02:26 AM
Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? alanhung85 CANADA 6 10-21-2014 10:41 PM
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP NickFRS Engine, Exhaust, Transmission 44 04-19-2014 05:42 PM
Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! TopGearSolutions Engine, Exhaust, Bolt-Ons 82 04-14-2014 08:16 PM
Gutted cat stock header vs aftermarket catless header NA application stevo585 Engine, Exhaust, Transmission 8 04-04-2014 04:12 PM
