Old 09-25-2018, 06:05 PM   #1
Adam_L
Adam_L's Avatar
Drives: '16 FR-S RS2 MT, '06 xA Polar MT
Lightbulb Chasis Brace , lower 2pt or 4pt question
Hello,
Just checking to see if someone can fill me in on the differences positives/ negatives on lower chasis braces. 2 point versus 4 point (H-brace) .
I have a 4 point H-brace on my xA that I installed over 5 years ago, it was a $60 deal on ebay made of aluminum. I did notice a tighter /stiffer chasis after installing (less flex) , more solid feel. I'm wondering if there is any negative /trade off in doing an install of a chasis brace.
Thank you
Math is like Love, simple idea at first that quickly gets complicated
Adam_L is offline   Reply With Quote
Old 09-25-2018, 06:45 PM   #2
norcalpb
norcalpb's Avatar
What are you looking to brace exactly?
I like the strut tower braces and the crossmember braces although they do add nvh.
Bracing the rear subframe is not common, and people typically do bushings instead.
Steering rack brace is also a great options.
A 4 point will simply have more mounting points than a 2 point, but cause more NVH. The only 2 piece crossmember braces I can think of are TRD (solid red metal) and STi (flexible draw stiffener)
Old 09-26-2018, 04:35 AM   #3
Adam_L
Adam_L's Avatar
What is NVH ?
The 2-point brace I was referring to, Buddy Club makes them ( check on ebay, they are made of a tubular steel I believe). I think it's just a simpler set up versus a 4-point H-brace. Even if you get two 2-point braces, that will help with some rigidity, but not as much as a 4pt H-brace ( it's like a Rombis shaped, or basically has triangular points, that help the chassis retain its rigidity.
I was mainly wanting to know the advantages / disadvantages of both. Is it more common to do once the car is lowered, to help with chassis rigidity?
Old 09-26-2018, 06:50 AM   #4
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
Noise Vibration Harshness
Old 09-26-2018, 02:06 PM   #5
norcalpb
norcalpb's Avatar
Originally Posted by Adam_L View Post
What is NVH ?
Can you link the buddy club braces?
A 2 pt brace will be more comfortable but less rigid. A 4pt brace will be less comfortable but more rigid.
Old 09-27-2018, 01:45 AM   #6
Adam_L
Adam_L's Avatar
Thanks for the info, that makes sense.
I think I may go with the 2-point braces then. Sorry, it wasn't Buddy Club, but DC Sports :
https://www.ebay.com/itm/DC-Sports-L...53.m1438.l2649
I haven't seen / or read specs on the TRD version, but probably not a lot of difference between TRD and this DC Sports ( it's a static component part). I'll look into that steering rack brace , see what info I can get on it
Old 09-27-2018, 12:27 PM   #7
wparsons
wparsons's Avatar
If you're not going to run all solid bushings between the control arm and body, these braces probably aren't going to do much.
In all honesty, unless you're doing it for the bling they're a waste of money for almost everyone.
flickr
The Following 4 Users Say Thank You to wparsons For This Useful Post:
churchx (09-28-2018), DylanJZA (05-24-2022), fatoni (09-27-2018), venturaII (09-28-2018)
Old 09-27-2018, 10:39 PM   #8
norcalpb
norcalpb's Avatar
Ok that is the rear subframe brace I was referring to. Only a couple people have done this.
You would actually need another DC sport bar that connects the most rearward subframe bolts to each other.
Now I am curious what kind of H-brace you were looking at, because most 4 point braces I've seen are only for the front of the car...
Old 09-28-2018, 03:47 AM   #9
Adam_L
Adam_L's Avatar
Thanks for the tips.
Yes, the H-braces I saw (Cusco , Tanube) , were for the front.
I think I'll back off this idea. If I was Auto-X driver, it would be a different story.
2019 , I'll probably do springs , and the Aero under panels , and call it quits.
Thanks again
Whiteline Front Lower Control Arm Brace g0odspeed Brakes, Suspension, Chassis 2 02-19-2016 07:16 AM
Stiffen up your FRS/BRZ with Agency Power 8pc Lower Brace Set vividracing Suspension | Chassis | Brakes -- Sponsored by 949 Racing 42 03-27-2015 03:56 PM
Brembo Front Brakes, APR Brake Ducts, GT Spec Rear Lower T Brace/Sway Brace, etc smellslikecurry Brakes, Suspension, Chassis 27 08-15-2014 11:52 AM
New Product! GTSPEC Rear Lower T Brace for 2012+ BRZ / FR-S vividracing Brakes, Suspension, Chassis 0 09-25-2013 02:19 PM
DIY - Password:JDM Strut Tower Brace & Lower Tie Bar Install xxscaxx DIY (Do-It-Yourself) Guides 15 05-14-2013 09:52 PM
