Old 09-20-2018, 08:43 PM   #1
mistople
mistople's Avatar
Drives: 2017 BRZ (Sold), 2023 GR86
Difference between Whiteline Diff Outrigger Bushings and Diff Cradle kits?
Can anyone shed some light on the differences between the two kits? I'm looking for an engine and diff mount solution to go along with my transmission mount insert, but I can't quite tell the difference between these two since they claim basically the same net effect.
http://www.ft86speedfactory.com/whit...nsert-846.html
http://www.ft86speedfactory.com/whit...t-kit-473.html
mistople is offline   Reply With Quote
Old 09-20-2018, 08:46 PM   #2
StraightOuttaCanadaEh
Wes
One is mount, one is bushing. Bushing reduces the slop by a good amount (about 40% for me), and mount is I think a replacement? I imagine a lot stiffer with more NVH.
Could be wrong!
Instagram: @gt86ws
Old 09-20-2018, 08:47 PM   #3
mistople
mistople's Avatar
Could be wrong!
So the outriggers are the bushings and the cradle is the mount?
Old 09-20-2018, 08:56 PM   #4
Wes
Yes I have the outrigger support and can confirm they're just bushings. The other one does indeed look like a mount replacement
Instagram: @gt86ws
Old 09-20-2018, 08:59 PM   #5
mistople
mistople's Avatar
Cool, thanks. I'll probably just do the bushings unless there is a compelling reason to do otherwise.
Old 09-20-2018, 09:30 PM   #6
Wes
I found it wasn't really enough. Car is still jerky. Definitely feels like it takes itself more seriously though. Putting in the rear subframe bushings in a couple of weeks and I think that's what will make the most difference.
Instagram: @gt86ws
Old 09-20-2018, 09:43 PM   #7
mistople
mistople's Avatar
That's my plan as well. Perrin engine mounts, whiteline transmission insert, diff inserts, and subframe bushings.
I thought about the Spoon rigid collars as well, but I'm not sure its worth the cash.
Old 09-21-2018, 06:25 PM   #8
JCW 86
JCW 86's Avatar
Drives: 2013 Raven FR-S
http://www.ft86speedfactory.com/whit...l#.W6VhATlKipo
Did you consider these instead of the rigid collars?
JCW 86 is offline   Reply With Quote
Old 09-21-2018, 06:31 PM   #9
mistople
mistople's Avatar
Yep, that's what I'm gonna do instead!
Old 09-21-2018, 06:39 PM   #10
JCW 86
JCW 86's Avatar
Whoops, I'm in idiot lol. Didn't see you mentioned the subframe bushings earlier
The way you're doing it is the way I plan on doing mine as well. Wanna stiffen things up but still keep it streetable without too much NVH. This car doesn't have much sound deadening as it is.
Old 09-21-2018, 07:01 PM   #11
mistople
mistople's Avatar
Exactly. Until I can trailer this thing in as a hardcore dedicated track toy, I need to keep it reasonable on the street.
Which is better? Reaplcing rear diff bushings? or installing rear diff brace? Frs30 Engine, Exhaust, Transmission 22 04-13-2020 11:23 AM
FS: Whiteline Diff Insert Bushings (KDT925) bombardius Brakes, Suspension, Chassis 2 04-16-2016 11:50 AM
Who has the Whiteline diff insert bushings? unsurety Northern California 4 09-09-2014 12:11 AM
Whiteline Diff cradle mount, steering rack bushings, etc.. Thongpocket Engine, Exhaust, Transmission 4 02-25-2014 06:26 PM
Whiteline diff bushings and trans mount insert. Simmons Transmission and Driveline 7 06-09-2013 09:45 PM
