Old 09-20-2018, 04:27 PM   #1
Nottcute
Drives: 2014 Raven FR-S
Help! Boormerang and taillight aren’t working
Ok, so on the free way, I ran over a pot hole and then my side marker, and driver side lining flew off. When I got home I noticed that my day time running lights aren’t working. I check all the fuses and changed them out. I also connected my boomerang lights to my fuse box , to allow them to turn on once my car is started. But now my taillights don’t work. But when I press the brakes they turn on. But other than that , they’re not on unless you press the brakes.
Nottcute is offline   Reply With Quote
Old 09-20-2018, 04:38 PM   #2
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Do your license plate lights work? Those are on the same circuit as your brake lights.
N1rve
Old 09-20-2018, 04:41 PM   #3
Nottcute
No they don’t work
Old 09-20-2018, 05:45 PM   #4
N1rve
N1rve's Avatar
No they don’t work
Double check the fuse #4 on the interior panel. If it's not blown, check the wiring for the side markers. Check for any damage in wiring.
I'm not sure which relay the boomer rang light itself is on, I've always thought that was part of the headlight circuit. Headlight is fuse #39 and #40 under the hood.
N1rve
Old 09-20-2018, 05:54 PM   #5
Nottcute
The signal mark wire is completely damaged, it’s just two espoused wires (black &red) I put electrical tape over them. But it’s still not working
Old 09-20-2018, 07:23 PM   #6
N1rve
N1rve's Avatar
You might need to splice or solder new wire into there. The wire might be too damaged to get a signal passed through.
N1rve
Old 09-21-2018, 02:37 PM   #7
Nottcute
problem solved, my fuse under my hood near the driver side entry wall there is a jumbo 15amp that was blown, changed that out and everything worked properly!!!
My Side Markers aren't functioning! srizzors25 Cosmetic Modification (Interior/Exterior/Lighting) 3 01-15-2016 03:52 PM
When someone says our cars aren't quick enough ButeraFRS Scion FR-S / Toyota 86 GT86 General Forum 31 04-11-2015 01:34 AM
Why aren't some concerned about putting a turbo on a high compression motor? dave77 Forced Induction 50 01-13-2014 02:22 AM
Is the BRZ interesting to drive when the roads aren't twisty? Slipstream BRZ First-Gen (2012+) — General Topics 65 12-06-2013 06:31 PM
Aren't hipsters annoying? gt8613 Off-Topic Lounge [WARNING: NO POLITICS] 142 08-20-2013 02:44 PM
