Old 01-13-2016, 08:30 PM   #1
srizzors25
Daedalus Moto
srizzors25's Avatar
My Side Markers aren't functioning!
Hey all.
I've been having an issue with my side markers up front not working. I've got a pair of aftermarket clear markers on there. For awhile they worked fine but for awhile recently the passenger side marker would blink randomly, as if it had a bad connection or something like that.
Recently I found that both markers were completely off and that occasionally the passenger marker would blink very weakly.
Just for good measure I replaced the bulbs that came with them with some new Diode Dynamics guys but neither work.
I read somewhere that this has happened to others but has been linked to tail lights not working via a fuse inside under the steering column. My tails work great and every other light seems to function normally.
Are there other fuses that could be linked or what? Any help would be appreciated!
Thanks
Old 01-15-2016, 07:41 AM   #2
PECK
Drives: 2015 Scion FRS
Check to see if moisture got inside the housing for them. Those aftermarket ones have a crappy weather seal.
Sent from my SM-T530NU using Tapatalk
PECK is offline   Reply With Quote
Old 01-15-2016, 01:47 PM   #3
srizzors25
Daedalus Moto
srizzors25's Avatar
I've been keeping an eye on them, no moisture. New bulbs too so they shouldn't have been fowled already.
Anyone?
Old 01-15-2016, 03:52 PM   #4
8R6
8R6's Avatar
Drives: FRS
have u tried replacing them with the stock filament bulb? my car had the same problem so i switched to different led's and still didnt work, but when i put the stock ones on, it worked normal again.
8R6 is offline   Reply With Quote
Helix Side Markers plus New SMD style Side markers 86SPEED Groupbuys 143 11-22-2017 06:25 AM
FS: Clear Helix side markers and OEM Amber side markers unlimited86 Exterior Parts (Aero, Lighting, Etc.) 15 07-06-2015 02:27 PM
FS GA: Helix Clear side markers/ OEM Amber Side Markers 86TruenoFRS Exterior Parts (Aero, Lighting, Etc.) 1 03-21-2014 06:06 AM
FT: Clear side markers for smoked side markers Red FRS Exterior Parts (Aero, Lighting, Etc.) 7 02-05-2014 05:52 PM
