Loud buzzing noise backing up with steering wheel turned
A new noise started yesterday and got really loud today. It happens backing up with the wheel turned over ~15* in either direction. What should I be looking for or is it the power steering motor and it just needs to be replaced?
Could be the motor, call the Subaru service dept and tell them the symptom. They may be able to answer without you going in.
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
Where does it sound like the noise is coming from?
If it's hard to tell, you may consider jacking up the front end and having your co-pilot turn the wheel while you try to locate the source. humfrz |
not playing cards
Only when backing up is weird. Are you sure about that, or do you only notice it when it's cold, like the first time you back out of a parking spot?
It only does it backing up, I'm sure. Car has to be moving, it doesn't do it with the front wheels off the ground and turning the wheel. The noise is definitely coming from up front somewhere. It's louder when the car is warm than when it's first started for the day. I almost always back into parking spots and always back into my driveway which means that I'm always turning pulling out of any parking spot or the driveway and it doesn't do it when pulling out.
Tomorrow I'm going to find a place where I can back up at higher speed than I have so far and see if it does it then too. It's very disconcerting especially when people turn around to look at you... |
| The Following User Says Thank You to gravitylover For This Useful Post: | Ultramaroon (09-16-2018) |
Drives: 2014 Subaru BRZ
Check your pads if you don't find anything else. I had my pads make extra noise when reversing when they were well worn (I run aggressive track pads all the time though).
| The Following User Says Thank You to 14stu For This Useful Post: | gravitylover (09-16-2018) |
I guess that could be possible, they're down to almost nothing. It sounded more like an electrical buzz but thinking about it you could be right.
Drives: 4wd zooks
Many years ago i parked in a back narrow lane and other cars parked very close , so i needed to go from left to right steering lock and move an inch at a time.
This caused the power steering to make an electrical buzzing noise. Never had this problem again because i won't park in back narrow lanes anymore. |
| Loud Buzzing Noise - Car Not Running | Apex_BRZ | Issues | Warranty | Recalls / TSB | 7 | 04-13-2014 06:00 PM |
| RPMs reving and dropping when steering wheel is turned | Bach415 | Issues | Warranty | Recalls / TSB | 24 | 03-05-2014 06:41 PM |
| buzzing in steering wheel | wbsrazzle | Issues | Warranty | Recalls / TSB | 2 | 05-15-2013 10:05 PM |
| Intermittent buzzing from below the steering wheel? | brzninja | BRZ First-Gen (2012+) — General Topics | 12 | 01-05-2013 11:01 PM |
| buzzing noise from steering wheel FR-S | :DK | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 10-07-2012 02:52 AM |
