Old 09-14-2018, 05:26 PM   #1
wild03
Drives: Silver 2017 Limited with PP
Question regarding alarm
Hi all,
Does anyone know if the BRZ comes with an alarm? I have the keyless start on the 2017, I can lock the car with key fob or by touching the outside of the door handle. but how do i test if there's an alarm? I have never heard the horn sound. is this an additional feature?
I tried doing this with the window down and i was able to unlock the door and open the door with out any alarm triggering.
I'll have to admit that this keyless thingy takes getting use to, i used to always check that the doors is locked but now the door just opens again if i pull on the handle because the key is on me, I would have to toss the key away from the car and check, ..sometimes i forget to lock it because i never have the keyfob on my hands. I close the door and start walking away....then realize i have to walk back to touch handle or pull keyfob from pocket...
A better system would have been to lock the car as soon as you close the door and car detects keyfob is outside.
Thanks.
wild03 is offline   Reply With Quote
Old 09-14-2018, 06:24 PM   #2
spike021
spike021's Avatar
Originally Posted by wild03 View Post
Hi all,
Thanks.
Press and hold the silver button with red speaker on it.
Instagram: @spike.grc
spike021 is offline   Reply With Quote
Old 09-14-2018, 06:25 PM   #3
wolffbite
Just the tip
wolffbite's Avatar
Drives: 2017 DGM BRZ
I think you can set it off by using the physical key from your fob to open the door or trunk while the car is locked. Shouldn't matter if you have the fob close by or not.
See this excerpt from the 2017 manual. It appears that the alarm is not activated by default, and needs to be enabled.
I actually don't know if I checked that the alarm came activated on my car... something I will check tonight.
wolffbite is offline   Reply With Quote
The Following 2 Users Say Thank You to wolffbite For This Useful Post:
TofuJoe (09-16-2018), wild03 (09-15-2018)
Old 09-14-2018, 07:36 PM   #4
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Hi all,
Thanks.
Was it not an issue on earlier cars that during delivery inspection or at the factory the alarm was disabled by default and never re-enabled during purchase inspection?
I seem to remember alot of people having that issue when I first joined the forums:
https://www.ft86club.com/forums/showthread.php?t=11049
Old 09-14-2018, 09:29 PM   #5
wolffbite
Just the tip
wolffbite's Avatar
Possibly. I just checked mine and it seems to be activated and I can see the blinking light on my dash when it is locked.
I remember having to activate the feature to unlock both driver AND passenger door when you touch the handle. Never touched the alarm settings though.
Though I think the kind of alarm we have will not get set off if someone smashes your window, only if they force a door open. I don't think it has any sensitivity to movement/impacts.
Old 09-15-2018, 12:31 AM   #6
R_E_L
He's got this.
R_E_L's Avatar
Drives: 50th Anni BRZ
As they have said above, some do. Mine did, but I had to activate it
Don't worry, I'm certified... promise.
R_E_L is offline   Reply With Quote
Old 09-15-2018, 12:50 AM   #7
wild03
Awesome info, thank you all. I will check this tomorrow and report back. I do see a blinking led on the dash now but not sure if it means car is locked.
Old 09-15-2018, 01:09 AM   #8
ShansBRZ
Drives: 2017 brz
Mine came with one but I installed an aftermarket one as well that integrates with the factory one. If you press the lock button three times the horn will honk.
ShansBRZ is offline   Reply With Quote
Old 09-15-2018, 10:54 AM   #9
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
Correct, there is no shock sensor, sadly.
You can add one though: http://www.ft86club.com/forums/showthread.php?t=90429
The Following User Says Thank You to B-R-Z For This Useful Post:
FRSBRZGT86FAN (09-16-2018)
Old 09-15-2018, 08:51 PM   #10
wild03
Looks like no alarm for me....and manual does say "if equipped" on top of the page...with switch on I pressed unlock and openned door held button for a wile and nothing happens, no Horn. Nothing on the dash indicating alarm is active as manual indicates. When I lock the car there's a red car and lock icon that blinks but I can open door with metal key and nothing happens.
Old 09-16-2018, 08:54 AM   #11
BRZnut
Drives: BRZ DGM Limited
yes, I was one of them. My 2013 came with the alarm off and I had to activate it. So its been the same going forward? Alarm set to off even today?
Old 09-16-2018, 11:32 PM   #12
wild03
As posted above on the picture of the 17 manual it states default is deactivated. But I followed activation process and nothing happened. 😒
Old 03-08-2019, 08:06 PM   #13
TofuJoe
Ohne Titel
TofuJoe's Avatar
Drives: 2017 BRZ PP ISM
@wild03 - The instructions are really unintuitive:
1. Make sure you've pressed the push button start twice, not once. That's the "On" position.
2. Hold the door unlock button down, and when you open the door keep the interior door latch handle pulled out for the entire 10 seconds (while you keep pressing the unlock button with the other hand).
TofuJoe is offline   Reply With Quote
Aftermarket alarm removed, now alarm system won't work DaviKiNui Electronics | Audio | NAV | Infotainment 1 01-20-2018 05:17 PM
Alarm question ogrowup Scion FR-S / Toyota 86 GT86 General Forum 22 12-26-2014 08:31 PM
quick question- does this car have car seat alarm? djmm AUSTRALIA 7 04-24-2014 01:15 PM
Alarm Sigh-on-Rice Hawaii 11 05-24-2013 02:15 PM
Alarm? ft86me Scion FR-S / Toyota 86 GT86 General Forum 10 04-15-2013 12:27 AM
