Old 07-28-2012, 11:12 AM   #1
jma
First mod, sort of....
https://picasaweb.google.com/1032840...eat=directlink
Found a use for the pretty useless center dash pocket. Scangauge fits there perfectly. The pocket is easy to remove, just clips. Slide you hand in it, press down and slide it out. Remove the bottom rubber cover, just glued there with double sided tape. Disconnect the USB plug and then it will be totally out. I drilled a small hole in the back for the cable, installed the gauge and voila:
All kinds of good info: AFR, intake and water temps, timing, MAP, voltage, TPS and so on. It also doubles as code reader.
jma is offline   Reply With Quote
Old 07-28-2012, 11:59 AM   #2
Khyron686
Drives: 2011 Outlander XLS, 2013 FR-S Blue
Pretty creative. Can you read it from driving position?
My Galaxy 2 fits in that pocket perfectly.
Khyron686 is offline   Reply With Quote
Old 07-28-2012, 12:01 PM   #3
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Drives: Lexus IS-F Series 2
Unfortunately something like that would not work on BRZ because our cubby is smaller due to the push button start
Looks great though
Sent from my GT-I9300 using Tapatalk 2
2URGSE
JPxM0Dz is offline   Reply With Quote
Old 07-28-2012, 12:42 PM   #4
kendalldwhite
kendalldwhite's Avatar
Drives: Mint-Tiffany blue FRS
cleaning install great job
kendalldwhite is offline   Reply With Quote
Old 07-28-2012, 02:31 PM   #5
jma
No problem reading from the driving position. Thank you for posting the pic.
Old 07-29-2012, 12:01 AM   #6
Username
Username's Avatar
Drives: 6MT Raven FRS, Toyota SR5 V6 4x4
Good idea.
I have found that cubby is the best place for my cell phone to live. Close to the USB for power, and prevents me from fussing with my phone since it is not easy to causally grab.
Username is offline   Reply With Quote
Old 07-29-2012, 12:08 AM   #7
Snoopyalien24
Mr. Sarcasm
Snoopyalien24's Avatar
Originally Posted by Username View Post
Good idea.
Doesn't it slide around a bit?
Cuz if it does, you can try this
Snoopyalien24 is offline   Reply With Quote
Old 07-29-2012, 12:30 AM   #8
eriktherod
Drives: 2013 Scion FR-S Firestorm Red MT
Oh man! That's lovely. My Scangauge has been sitting on my desk for the past few weeks. I've been thinking of an install location but didn't even think about that pocket!
Do you have some more pics of the overall view?
EDIT: Just saw some questions answered above. Oops! Still curious of where you drilled the hole!
eriktherod is offline   Reply With Quote
Old 07-29-2012, 07:39 AM   #9
crimespree
Drives: 86
this is exactly where i was thinking, but don't have car yet, cheers...
crimespree is offline   Reply With Quote
Official Weight Reduction Thread - Sort of... merlin2111 Off-Topic Lounge [WARNING: NO POLITICS] 77 10-07-2012 05:09 PM
I will probably only have this sort of luck once in my life... joshua BRZ First-Gen (2012+) — General Topics 9 07-11-2012 08:08 AM
FR-S Test drive..well, sort of... CSSM Scion FR-S / Toyota 86 GT86 General Forum 10 06-08-2012 08:07 PM
