Old 02-03-2017, 05:30 PM   #1
sebgrami
MUKN ronin
Drives: silver stock
Air flow for heater/AC
Hi, this is my first time posting or asking a question. Whenever I have issues this forum has helped out a lot. So this is the issue I'm having right now.
The air flow for my car will once in while not work. No air flow for heat or A/C, has anyone else had this issue?
Any input would be appreciated.
sebgrami is offline   Reply With Quote
Old 02-03-2017, 06:15 PM   #2
By no airflow do you mean the fan doesn't come on or just nothing is coming out? Did you have your dash apart for any reason such as changing the HU?
Old 02-04-2017, 12:17 AM   #3
humfrz
Hi sebgrami and welcome to posting ........
If the fan is not running from time to time, first I'd check the fuse (maybe it's lose) then the connection to the fan motor.
If the fan runs but no air comes out, you may wish to check the cabin air filter. Next would be check to see if a vent control cable is binding ..... like @Tcoat was getting at.
Update us.
humfrz
Heater hose Vic_RSA AFRICA 2 09-28-2016 04:43 AM
WTB: OEM Mass Air Flow Sensor/Meter Assembly Air Flow Sensor driftking96 Want-To-Buy Requests 0 02-16-2016 03:57 AM
Is there an OEM block heater? KevinBRZ BRZ First-Gen (2012+) — General Topics 1 08-22-2013 01:18 PM
Heater control weirdness FRiSson Issues | Warranty | Recalls / TSB 0 03-29-2013 10:33 AM
Seat heater temperature? milenko11 BRZ First-Gen (2012+) — General Topics 29 09-20-2012 01:19 PM
