Old 09-10-2018, 10:02 AM   #1
fang_gt86
FR Noob
fang_gt86's Avatar
No 2nd Gear After New Parts
Hey guys. I couldn't get my car to go into second gear after I installed the Exedy OEM kit - flywheel, pressure plate, clutch, and TOB. Refilled with Motul 300 fluid. I've checked the shift lever cap and it's installed correctly.
Symptoms:
1.) Won't go into 2nd gear and felt like it's not there anymore.
2.) 1st gear felt like 3rd gear. Reverse gear works.
Any help will be much appreciated and thanks!
"I'm having too much fun to care about horsepower" - Unknown
6MT FR-S Whiteout:OFT- OTS V2 Stage 2 (93oct & E85), Tomei UEL, Invidia OP, JDL UltraQuiet FP, Ark Grip catback, GS hood struts, Perrin Inlet & K&N drop-in
fang_gt86 is offline   Reply With Quote
Old 09-10-2018, 11:23 AM   #2
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Symptoms:
Not sure about the 2nd, but a buddy just replaced his clutch/tob/etc as well and had 2nd gear issues. The reverse lockout can interfere with 2nd gear if not reinstalled exactly right. Might be a good place to start.
Old 09-10-2018, 11:38 AM   #3
fang_gt86
FR Noob
fang_gt86's Avatar
I'll mess with the reverse lock-out again.
Old 09-10-2018, 11:43 AM   #4
churchx
churchx's Avatar
Drives: 2014 GT86
finch1750: reverse lock-out .. something in gearbox, or on shifter handle or anything more specific as to what exactly needs extra attention?
Old 09-10-2018, 12:05 PM   #5
finch1750
finch1750's Avatar
Let me see if I can get my buddy to chime in. I only know cuz I drove his car and 2nd would be locked out sometime and thats the reason he gave me.
Old 09-10-2018, 12:23 PM   #6
Sypher
Sypher's Avatar
Drives: '13 Ultramarine FR-S M/T
My problem stems from the reverse lockout guide that is bolted down under the shifter boot. It's basically the tab that prevents you from going into reverse until you lift the lockout on the shifter. If it's not aligned properly you will have issues with running into the "gate" when trying to shift into 2nd. When you shift into second try and make sure you go straight back and not slightly to the left. If it goes into 2nd it's the lockout tab.
Mod List:
FT86SF Catted header / Nameless combo pipe with cat and res/ FT86SF V1 CBE / GrimmSpeed Intake / OFT STG 1 GS Tune / Fortune Auto 500's
Sypher is offline   Reply With Quote
Old 09-10-2018, 12:28 PM   #7
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Can you get into 2nd with the lockout raised?
Old 09-10-2018, 12:45 PM   #8
fang_gt86
FR Noob
fang_gt86's Avatar
I will have to try that later.
Old 09-10-2018, 12:49 PM   #9
ermax
ermax's Avatar
I will leave this here:
https://demos.starbase7.net/t3Portal...73598848384294
Old 09-10-2018, 12:54 PM   #10
fang_gt86
FR Noob
fang_gt86's Avatar
Originally Posted by ermax View Post
I owe you a beer if this solves my problem!
Old 09-10-2018, 01:21 PM   #11
ermax
ermax's Avatar
Nah.. give it to @finch1750. He had the answer first. I was just adding the manual page to make the job easier.
Old 09-10-2018, 07:41 PM   #12
fang_gt86
FR Noob
fang_gt86's Avatar
Thanks guys. She's alive!
Old 09-10-2018, 08:07 PM   #13
Lantanafrs2
Drives: 2013 frs red
Now that's how these forums are supposed to work. Bravo!
Gear indicator (G-on) shows 2 when in 3rd gear c8Face BRZ First-Gen (2012+) — General Topics 31 07-07-2017 07:23 PM
Loud Hum/Grinding Noise + Vibration in 5-15mph gear range, in gear and rolling neutrl jakebrz Issues | Warranty | Recalls / TSB 14 06-06-2016 06:28 PM
Auto gear slippage on 2nd n 3rd gear shantha Scion FR-S / Toyota 86 GT86 General Forum 2 11-19-2015 07:26 PM
Low Idle/Cam gear - Anyone request to inspect your old/replaced parts? ahausheer Issues | Warranty | Recalls / TSB 7 08-26-2012 03:31 PM
Reverse gear on the first and second gear side randytindoggy Scion FR-S / Toyota 86 GT86 General Forum 50 01-29-2012 01:21 PM
