Old 09-02-2018, 01:57 AM   #1
wild03
Drives: Silver 2017 Limited with PP
Question regarding key fob.
Hi all, when I bought the car dealer only had one key and said it would mail me the second when whoever had it returned from vacation a week after, Its been 2 weeks and they cant f ind it so i was told they would order one and i had to go to get it programmed to the car.
Since dealer is pretty far I wanted to make sure i get the right item. Are both key fobs identical? i have keyless start. there's a metal key on the one i have now. Thanks.
wild03 is offline   Reply With Quote
Old 09-02-2018, 03:12 AM   #2
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
They should be identical and both should enable the remote start
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
wild03 (09-02-2018)
Old 09-02-2018, 07:49 AM   #3
Willie Swoopes
Junior Pizza Joe
Willie Swoopes's Avatar
Drives: 2017 BRZ Limited Manual WRB
With the Limited MY17, you should have gotten two fobs for keyless access and keyless start, they both have a small physical key inside them.
If you have the small metal tag with a 5 digit number on it you can get the key cut. I think the dealer needs the car to program the replacement fob to match your locks/ignition switch though.
It's a good reason to take a drive. Good luck with your BRZ.
Bill
Scooby-Doo: Scooby-Dooby-Doo!
Shaggy: And like, Shaggy too.
Willie Swoopes is offline   Reply With Quote
The Following User Says Thank You to Willie Swoopes For This Useful Post:
wild03 (09-02-2018)
Old 09-06-2018, 10:59 PM   #4
wild03
OK, went to pickup key today, 50min drive.
I was given a key that was clearly used, not that bad, but not out of the box, about the same wear as my current key fob after 3 weeks of use or so. I'm ok with that, But then I tried the metal key and its not the one for my car. Were they hoping i didn't notice? or honest mistake?
Guy apologized and asked me to come back next week. Filled my fuel tank which was 1/8 full.
He claims that the guy who programs keys comes every Thrusday, and that he was programming 3 keys today and gave my key to someone else...He will have my key next Thrusday....wow
Turn Signal Relay Question (Dumb Question) Chimera Cosmetic Modification (Interior/Exterior/Lighting) 3 06-23-2017 01:58 AM
FI question Christopherkuchta Forced Induction 3 08-29-2016 05:49 PM
Question for the the 2014 Brz Nav Owners (BT Question) jbsali Electronics | Audio | NAV | Infotainment 3 07-16-2014 11:41 AM
BEspoke question and rattle question bdanisi Electronics | Audio | NAV | Infotainment 2 01-30-2013 02:11 PM
Question about going FI with an AT mechaghost Engine, Exhaust, Transmission 1 06-28-2012 04:25 PM
